Brakes won't hold the car
Old Apr 14, 2004 | 10:49 PM
blackbeauty's Avatar
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
Hi everyone,
I'm sure something has to be up with my brakes. I can't even do a burn out and smoke the tyres because my little LG4 305 just pushes the car along (fortunately with some resistance from the brakes). Granted, my 305 surely isn't quite stock because it seems to have more snot than other cars of the same year, but even so, not being able to even have the car stationary and do a burnout just ain't right. I know third-gen brakes aren't the best anyway but I've seen plenty of video clips with guys doing this.
What is likely to be the problem? I have new pads installed and the rotors aren't warped either. They are however at their minimum thickness as it wouldn't be wise to machine them any further.
Any thoughts?
Old Apr 15, 2004 | 03:43 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
talk to ed miller about getting some ls1 brakes or you could always get a line lock kit. if you dont want to do either of those, i suggest you check your fluid level and condition
Old Apr 15, 2004 | 05:34 PM
Car: 1989 Trans Am
What's special about LS1 brakes, are they just bigger? I've got 14" rims so would they fit on my car?
Just yesterday I got the right hand side brake hose replaced so presumably they've changed the fluid also. The fluid level looks good. I've drag racing this Sunday so I'll give it the car a spin and see what if any difference is made.
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
zeitghaist
Aug 18, 2015 07:33 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
