Alignment Issue
Old Apr 15, 2004 | 06:04 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Alignment Issue
Hey, My car has new tires, shocks/struts, discs and pads.
It got an alignment.. tho the car simply wont stop pulling
to the right.. sometimes left.
Im confused .. my instincts tell me the alignment
was poorly done.. tho the mechanic said the big tires follow the road. I dont trust him.. tho dont want to bash someone for
nothing..
Any experience with such an Issue?
Tnx
Old Apr 15, 2004 | 06:17 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Bigger tires do tend to follow the road and the grooves in the road more than skinny tires. Check the grade of the road when it pulls. Cars not just the ones with wide tires tend to follow the grade anyway. You can change the camber or caster in an attemp to elimate it in one direction but the road pull will be twice as bad on roads that are graded the oposite way.
Old Apr 16, 2004 | 09:06 PM
Spectre's Avatar
Engine: 3.0L/183
well then, i guess I should move cause most of the time, the steering wheel is slightly tilted for the car to go straight.
THo sometimes it drives no problems..
I guess those shocks really plaster the tires to the ground..
Old Apr 16, 2004 | 10:34 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
What's it like on a realy good road.
I have 275s on the front and my car will grab any imperfections in the road but on a smooth road I can take my hands the wheel and the car will go straight until something in the road deflects it.
Sometimes it'll get on one of those grooves that trucks make in the centre lane and the car darts right and left but it's pretty obvious to me when it's the road causing the problem because otherwise it cruises fine.
Could be that you've got worn front end parts too and new/better tyres & shocks etc will accentuate any other problems in the suspension.
If most of the time you have the wheel tilted on good roads there could be a problem.
Old Apr 17, 2004 | 08:00 AM
Spectre's Avatar
Engine: 3.0L/183
Ill go have the suspension checked out.. see whats wrong ..
Tnx for the info
Old Apr 17, 2004 | 09:44 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
it could also be in the alignment, most alighments have a slight diffrent caster settings right/left to make up for the crown in the roads normaly about .5* extra caster on the right.
check for warn parts, i would also try to find out what exactly the specs are that the car was aligned to.
Old Apr 18, 2004 | 09:16 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
collapsed brake hose causing the brake to hang and pull the car???
Bubbajones_ya
Jul 6, 2024 08:32 PM
MM2Robinson
Oct 1, 2017 09:16 AM
88rscamar0
Sep 23, 2015 09:08 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
