Where to get alston WELD ON sfc's?
Old Apr 18, 2004 | 07:48 PM
25THRSS's Avatar
Where can I get the weld on, not bolt on, version of the alston subframe connectors?
Old Apr 18, 2004 | 10:17 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
TopDownSolutions, look at the top of the page, he's a sponsor.
Old Apr 18, 2004 | 10:20 PM
25THRSS's Avatar
That is the bolt on version. I am asking about the weld on version.
Old Apr 18, 2004 | 10:24 PM
drain89's Avatar
I have always been of the understanding that they are the same thing, one just comes with bolts and the other doesn't. Mine are welded on!
Old Apr 18, 2004 | 10:26 PM
25THRSS's Avatar
There are 2 versions, the bolt on and the weld on. I remember seeing them a while back and they were a lot cheaper too, but I can't seem to find them now. Anyone know?
Old Apr 18, 2004 | 10:34 PM
drain89's Avatar
I don't think any such animal exists, at least not anymore. I priced around before buying mine a couple months ago and lon was the cheapest. I paid around $175 for mine bare without the hardware. MAC makes a set that are basically the same and cost less but they don't have the "cups" that attach around the frame-rails. They are a weld on design, and I assume that they were probably modeled after these weld-on style alstons that you speak of. I went with the ones TDS sells because of how they saddle the frame-rails, thus giving me more of a contact area to weld. I don't know if that would make any difference....but it makes me happier.
good luck
Old Apr 21, 2004 | 05:38 PM
Pat Hall's Avatar
The Alstons are bolt on/weld on. They're one in the same. I had mine bolted on initially, now they're welded.
Old Apr 21, 2004 | 10:01 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I can get them from Alston. Are you aware that you need to hack the floorboard to install them? I mentioned this topic with Mike Ruth at Alston when I visted their facility today. He said they are still available, but they aren't really showing or promoting them any more. The bolt-in version is a much cleaner and easier product to install and gives you the option of welding them. But if you want them, just let me know. IMO, the cost savings isn't worth the extra installation hassles.
Lon
Old Apr 22, 2004 | 12:42 AM
25THRSS's Avatar
Lon
Gotcha. I had heard that before, but didn't know for sure. thanks for the info Lon. I'll be ordering the alston bolt on's soon.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
