parking brake screw
Old Apr 26, 2004 | 08:26 PM
sephiroth99's Avatar
Car: 86 z28
Transmission: t-5 original
parking brake screw
hi there i have a little problem with the screw for the parking brake that is above the driveshaft whenever i was driving i would always hear this metal scraping noise. I though it was my brakes, i took everything off and nothing then i got the idea to check the driveshaft for anything that might be touching it. Well come to find out the parking brake screw is very long and whenever i would go over a dip in the road at higher speeds it would scrape againt the driveshaft causing the metal scraping noise. Anyways does anyone have any clues on how i can go about fixing this? thanks
Old Apr 26, 2004 | 08:38 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
If it's hitting the driveshaft, that tells me that your e-brake cable is way too loose. There's an adjusting nut on it. Hold the long screw with a wrench and turn the nut so it goes toward the front of the car and that will take the slack out of it.
Ed
Old Apr 26, 2004 | 09:52 PM
Car: 86 z28
I already tried that, it didnt seem to work but ill give it another try any other suggestions would be great also
Old Apr 26, 2004 | 10:11 PM
ebmiller88's Avatar
If it won't tighten up, I'd think one or both of the cables is/are broke...that's the only reason that the cable wouldn't get tight. See if you can pull one all the way out.
Ed
Old Apr 27, 2004 | 02:59 PM
Car: 86 z28
ok today i tried tightening it up but that didnt work so i was wondering if i could just cut the excess off i mean there is like 5-6 inches of excess screw. But would it have any ill effect on remove about 1-2 inches of the screw? thanks here's what it looks like
Old Apr 27, 2004 | 05:52 PM
ebmiller88's Avatar
That's my car in your pic. No, it won't hurt anything to cut a bit off, there's plenty of it there.
Ed
Old Apr 27, 2004 | 05:59 PM
Car: 86 z28
cool thanks for the help
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
LittleFranks
Sep 17, 2015 12:22 PM
