torque arm noise
Old May 3, 2004 | 12:36 AM
chevycamaro92's Avatar
Car: camaro
Engine: 350 chevy
Transmission: super t-10
torque arm noise
Hey! I got the spohn adj. t/a with the sphyrical rod ends with a super t-10 x-member in my 92 camaro and ever scince i have put it in there is a pounding noise like someone hitting it with a hammer it also seems like exsecive bucking it is very anoying... how or what could i do to solve this problem? P.S. i tightend the sphyrical rod end on the crossmember with a 400 lb torque impacti have don so many things and spent money and still cant get it...
Old May 3, 2004 | 01:03 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Think I heard about this, has to do with the nut that fastens near the transmission crossmember, I don't remember when they spoke about it though.
Old May 3, 2004 | 02:46 PM
5.0Camaro's Avatar
Car: 1991 camaro Z28
I just put on the spohn torque arm but with the poly end. I've heard of this sound(tho i dont got it) from what i've read its because you dont have the nut tight enough where the spherical end connects to the crossmember. You have to put some torque on it(i tighten it down basicly as tight as i could no sound here). I guess the bolt is just a little smaller then the diameter of the poly/spherical end, plus you have to remember that the spherical end is going to transfer more noise then the poly, hope this helps.
Old May 4, 2004 | 11:24 AM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Mine does this as well, and with a 5 speed it's LOUD & frequent!
Old May 4, 2004 | 05:56 PM
5.0Camaro's Avatar
i have the 5 speed but i have no noise, but i tightend that bolt down pretty damn hard so..
Old May 4, 2004 | 08:48 PM
SweetRide45's Avatar
I got the Adjustable Spohn Torque Arm w/ Spherical End...I havn't put it in yet, but I talked to Spohn, and he said he uses high quality QA1's and shouldn't transfer that much noise...so, hopefully it'll go smoothly!!
Old May 4, 2004 | 11:34 PM
5.0Camaro's Avatar
it prolly wont be that bad prolly just a little more gear noise....my dad ordered the torque arm for me and i forgot to specify which one or i would have gotten the spherical end. Like i said with my poly/spherical combo ends on the lca and panhard it was barly an increase at all just a little more road noise on the freeway(but hey thats what the radio is for)
Old May 4, 2004 | 11:37 PM
Sounds good to me
Old May 5, 2004 | 12:46 AM
Car: camaro
Engine: 350 chevy
today i have solved my slamming noise problemi impacted the rear sphyrical rod ends (that attatck to rear end bracket) and i had placed a rubber stop on the top of the rear end bracket cause i thaugh it was hitting the floorboard ( but i dout that) and i took a ride and i havent heard it all day the key i thiink is to make sure every end is super tight...
Old May 6, 2004 | 12:07 AM
91Z28-350's Avatar
I have that too, and it doesn't really go away no matter how tight you get those bolts. If it's not tight, you will really hear it, but if it is tight, only when the rear gets pounded on. The poly bushing's opening is larger than the bolt and it will jiggle around. I thought that was weird, since there is play designed into it.
Old May 7, 2004 | 11:44 AM
Car: camaro
Engine: 350 chevy
mine deffinetly went away... no noise at all just a smooth ride
Old May 7, 2004 | 12:31 PM
pasky's Avatar
I think if you have loosened the bolt once or twice after tightening it the bushing will become loose and you will hear the bang no matter what, im still trying to read where the hell I read this if it was here or another board. That may be why your're clunking.
Old May 7, 2004 | 05:40 PM
5.0Camaro's Avatar
you should put some lock tight on it then tighten them down pretty hard that should do the trick......if not i dont know cause that worked for me.
Old May 7, 2004 | 10:11 PM
Car: camaro
Engine: 350 chevy
I took a really powerful impact 1/2 inch drive torque the front sphyrical rod end till the welding broke.. so i went to lowes hard ware and baught a grade 8 5/8 bolt and uesed the nut that came with the torque arm and really really tighted it..then i torqed the rear rod ends but i also placed a 2 inch rubber stop in the outer rear bolt wholes (the front whole) and never heard or felt it again
Nervous2
Oct 8, 2015 10:53 PM
89newfun
Sep 16, 2015 09:28 AM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
