What To Do Next?
Old May 9, 2004 | 09:34 PM
shipfitter_sjd's Avatar
Car: 1992 Camaro RS Convertible & 1983 P
Engine: 305 TBI & 305 4 BBL & 4.7 liter
Transmission: Auto & Auto & 5 Speed Manual
What To Do Next? Sub Frame Connectors?
I have a 90100 mile 1992 Camaro RS convertible. I have just completed the following tasks on my car:
1) Replaced front and rear springs (OEM style).
2) Replaced shocks and struts (KYB).
3) New bump stops on rear axle.
4) Installed Spohn tubular lower control arms.
5) Installed Spohn tubular panhard bar.
What should I do next? Bearing in mind that there is a budget to keep in check, please!
Thanks,
Steve
Old May 9, 2004 | 10:14 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Subframe connectors for sure!!!
Old May 10, 2004 | 12:53 AM
5.0Camaro's Avatar
Car: 1991 camaro Z28
yea subframe connecters are one of the first things you should prolly do. After that i would do a wonder bar or stb.
Old May 11, 2004 | 03:19 PM
[B]Sub Frame Connectors[/B]
Sub Frame Connectors. Do they really work? Can you actually, physically feel a difference in the ride or handling of your car after they are installed?
Since my car is a convertible, I noticed that there are not too many manufacturers of sfc's for convertibles that are 3rd gen.
I also noticed that there is no real set style or type of sfc's. For example, I went online and compared Spohn's sfc's to those by TDS (Top Down Solutions). Which is better? Do they do the same job, just taking different routes?
Just curious.................
Oh, a final question that just occurred to me...........
Is it better for the SFC's to be bolted in or welded in? Is there a downside to bolt ons?
Thanks,
Steve
Old May 11, 2004 | 08:42 PM
I have not done it yet...but if you pay attention to these boards they all say that it is the one most important suspension mod. Try a search and you will see. Also, I think Spohn performance(Sponsor up top) does make a set for convertables and they make top of the line products.
Old May 11, 2004 | 08:59 PM
"1) Replaced front and rear springs (OEM style).
5) Installed Spohn tubular panhard bar. "
Spohn does make great products, see 4 and 5 above. I am just curious about the different style or approach to solving or remedying a common problem amongst 3rd gen f-bodies.
I would like to do the mod. We will see which project will get my attention first!!
Thanks,
Steve
Old Jun 3, 2004 | 10:35 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
All subframe connectors for third gens try to accomplish the same thing; they help keep the chassis stiff and keep it from flexing and, to a degree, offload stress onto the actual suspension components of the car.
I don't think there is really one "best" set of subframe connectors. If you ask the people here which ones to buy, the answers would range from Spohn's to Kenny Brown's to Alston's and a variety of many other brands. Just keep in mind they all serve the same purpose.
Since you have a vert, I'd personally recommend Spohn's SFCs because I know they have a set specifically made for convertibles.
Old Jun 4, 2004 | 01:54 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
some claim that the spohn ones are better for handling since theyre along the outside (cant think of a better way to describe it) and say the alston (TDS) are better for drag racing. either way you cant go wrong
