replacing front rotors....what else?
Old May 17, 2004 | 08:46 PM
squirrelybird's Avatar
What is required or part of the process of changing the front brake rotors?
for example, if i put on new rotors, do i need to do bearings? ball joints? studs?
explain it all, because i just dont know.
Old May 18, 2004 | 12:59 AM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
get new inner and outter bearings with seals. also if your calipers are original its probably not a bad idea to change those too, they arent too expensive. other then that theres nothing really you'd really change unless you had a problem. upgrade the brake line maybe if your going to change the caliper.
Old May 18, 2004 | 01:46 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
The front calipers are $11.99 each at advance autoparts. With $10 cores for your old ones.
Very cheap. I plan on getting them soon just for safe measure. Plus I get a 20% discount off the 12$ calipers lol.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
