What grease should I use?
Old May 20, 2004 | 02:05 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I just got my Lakewood LCA's in the mail. What kind of grease should I fill them with? It says "a good brand grease" or something like that. I was wondering if I need a lithium based, synthetic or whatever. Thanks in advance.
Old May 20, 2004 | 02:18 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Go with the white grease Spohn offers. It stays where you put it and the tube will last you a long time.
Ed
Old May 20, 2004 | 03:18 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
I use Mobil 1 Synthetic.
Old May 20, 2004 | 08:23 PM
Transmission: 4l60e
we carry the mobile 1 synthetic grease at work I will probably try that.
Old May 21, 2004 | 01:53 PM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
conventional grease and polyurethane bushings supposably don't mix. go with synthetic grease - the white sticky stuff.
Old May 21, 2004 | 07:05 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I think the sticky grease is sold under Marine Grease.
Old Sep 26, 2005 | 07:35 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
The Synthetic Grease Spohn sells is like 14 a tube but I know that is the kinda I need (white sticky stuff) for my poly boots. Is the Moible 1 Synthetic grease also the "white sticky stuff" also. I dont want to pay a bunch for the stuff Spohn has on its site if the Moible 1 brand is the same thing.
Kevin
Old Sep 29, 2005 | 03:13 AM
83 Crossfire TA's Avatar
Bull****. Almost nothing chemically attacks poly bushings. You can use any grease you feel like using or whatever is already in your grease gun.
The thick, sticky stuff (usually clearish or milky colored) is actually just a “marine” grease which is less likely to wash away (same stuff used in boat trailer wheel bearings). It’s not necessarily synthetic and the only reason that it originally became the standard for poly bushings is that none of them used to come with grease fittings so something that was sticky and tended to stay put would tend to keep things lubed longer. It's not necessarily a better lubricant, but if the choice is somethign OK or somethign that will wash away and not be there...
Another thing people used to use is the silver antisieze (which is just about impossible to wash off of stuff.. I hate the stuff).
The “superlube” that spohn sells is just a light grease with some Teflon added to it, you can get it at most hardware stores and bike shops (they use the stuff to lube bike shocks). The only advantage to the stuff is that it’s fairly clean (clear, not messy) compared to most greases.
I usually whatever chassis grease is loaded in my gun, which right now I believe is some heavy duty, moly chassis grease fortified with Teflon (I got 2 tubes free with the grease gun, nothing special about it but it is nice that it’s died green an relatively not messy)
Old Oct 1, 2005 | 12:56 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Agreed.
I am using EP2 (regular lithium based grease) I have seen it in red, blue, green and black, so you could color match it to the bushings too.
Old Oct 1, 2005 | 05:13 AM
CrazyHawaiian's Avatar
Car: too many ...
I use Mobil 1 Synthetic on all my bushings.
Old Oct 1, 2005 | 07:32 AM
ebmiller88's Avatar
The Synthetic Grease Spohn sells is like $14 a tube but I know that is the kinda I need (white sticky stuff) for my poly boots.
Look local...I found that same stuff for $7 per tube here.
Ed
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
Numbah-1
Sep 12, 2015 08:57 PM
dyeager535
Aug 28, 2015 08:10 AM
