Lower Traction Bars (Spohn)!
Old May 25, 2004 | 11:09 AM
Maximus's Avatar
Car: 1992 Camaro Z28
Transmission: 5spd.
WOW!!! Just installed the non-adjustable lower control arms, w/ the relocation brackets!!!! What a difference, once I get on the car traction is instant! Having new tires helps, but I highly reccomend the combo! Thank you Spohn, we will meet again!!!:hail: :hail: :hail:
Old May 25, 2004 | 02:57 PM
SweetRide45's Avatar
Good deal. I already have my Relocation brackets welded on and am putting Poly/Rod LCA's on her very shortly.
Old May 25, 2004 | 09:54 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
could they be made @ home
I'm cheap and I would like to make them at home. Do you think it is possible?
LB9GTA
Old May 25, 2004 | 09:56 PM
Maximus's Avatar
Transmission: 5spd.
If your good at that kind of thing, anythings possible! Good luck if you do, and post pic's!
Old May 25, 2004 | 10:18 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Could you post a pic of them installed? Do you remember the measurements?
LB9GTA
Old May 26, 2004 | 12:50 AM
Kaas's Avatar
Car: 89 Iroc-Z
i am going to have to install some lower control arms here soon (within the next week or so) and was wonderin how hard it is to do? i was gonna get the ones with the adjustable bushings...what you think guys? need help if anyone can respond so that i know wiether to order them or not lol...and also, do they come in pairs, or is it 155 for just one of em?
Old May 26, 2004 | 06:15 AM
Dr G's Avatar
Re: Lower Traction Bars (Spohn)!
Maximus:- Is your car lowered? Or standard ride height? Which hole are you using in the relocation brackets?
Kaas:- Yes, they come in pairs.
Old May 26, 2004 | 08:28 AM
frogmanjohn's Avatar
Car: 89 RS
Engine: 305 TBI 215,000+
same question as kass, are the adjustable ones worth the extra money?
Are they in any way weaker than the non adjustable ones?
john
Old May 26, 2004 | 09:41 AM
Maximus's Avatar
Transmission: 5spd.
From what spohn told me they are the same, the only difference is that you are able to adjust the front to back placement of the rear! I didn't think that would be a problem for me so I went w/ the non-adjustable! Awesome upgrade, as for the hole, I went w/ the lower bolt opening. You can always change that!!! Next will be the subframe connectors, probably in july!!!!
J-money
Jan 4, 2019 09:45 AM
Numbah-1
Sep 12, 2015 08:57 PM
Nick McCardle
Sep 10, 2015 08:36 PM
87camaro87
Sep 9, 2015 10:29 PM
