1986 Trans Am - want to go to 17's or 18's
Old May 28, 2004 | 11:42 AM
bigwheelz's Avatar
1986 Trans Am
What specs do I need to know about upsizing to 17's or 18's? Offsets, and I would need to go to bigger tires...what is the best option for the 17's or 18's?
Thanks for any help
Old May 28, 2004 | 12:39 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
All depends on what wheels you want..
Old May 28, 2004 | 02:50 PM
bigwheelz's Avatar
I guess I need to know the specs of what will fit..then I'll go looking for brands.
Old May 28, 2004 | 11:09 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
i think I have a 0mm offset on my rims. I ran 17x9 all the way around.
They said something about I might need to adjust the car to put 17x9 on the front but it bolted on just fine. No rubbing or anything out of the ordinary so I don't know what they were talking about
Old May 30, 2004 | 02:00 AM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Your car is sitting pretty high...if you lowered it some more you would likely have to crank in some negative camber to stop the fronts from rubbing the tops of the fender. That's probably what they meant.
Pilotrick50
Sep 2, 2015 12:48 PM
michealleger
Aug 26, 2015 03:29 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
