How Speed Bleeders Work
Car: 89 Camaro I-Roc z
Transmission: Th700r4
I just bought a cheapo set from Autozone to see how they work.
This is a simple diagram oh how they work. essentially there is a small flap in the middle that does not allow air in... only brake fluid out.
anyways, the diagram should be self explanitory but for the pictorially uneducated... the screw closes the passage via a compression flare. when slowly opened a hole in the side allows the fluid to leave through the top.
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
they work fine for one or two tries- What happens then is the teflon coating that the threads rely on for sealing out air will wear off and you will suck air back through the threads.
Earls Solo-Bleeds are a much better design. The spring is behind the threads, not inside the unit itself. So the threads never require sealing for the unit too work.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
heres another pic.
as for the thread wearing thing... im still waiting for that to happen... its been 6 years.
i think its either a myth because it SEEMS like that could happen, or the people wearing it out are autoXers who change fluid 50 times a year.
Car: '87 Cam RS V6
Engine: Top Secret
I owned a set of Russells, They wore out the third time I tried to use them. Thats when I switched to Earls. Only expressing my experience with them.
Car: 91 Camaro Vert
Originally posted by HamSpiced
People with the earls solo bleeders.... got a summit part number?
you only need one number
800 230 3030... after that, they should be able to look it up for you.
Can you be a little bit more descriptive, there are three numbers there, actually 3 sets of three so 9.
and that doesnt follow the Summit part number syntax
1992 Trans Am
Aug 8, 2015 08:16 PM
