Done With Engine WOrk, Moving On To Suspension 101
Old Jun 8, 2004 | 10:56 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
ok I was lookin at my jegs catalog, im planning on gettin the eibach pro-kit springs, and a tower brace, and a rear sway bar, but what is a panhard rod, or trailing arms, what are their purpose and what kind should i get?
Old Jun 9, 2004 | 12:47 PM
Intensity_Z's Avatar
Car: 84Z/ 87 S-10
Engine: 355/350
Transmission: th-350/700-r4
well the panhard bar keeps the rear end centered on the car, and the trailing arms (lower control arms) connect the rear end to the sub frame and allow the rear to articulate, also aftermarket ones will help eliminate wheel hop where as the stamped steel one flex and twist
as for what kinds to get, if your going for a race application then i'd suggest spohn rod/spherical adjustable LCA's and pan hard, with LCA relocation brackets, and a adj. torque arm wouldn't hurt either a
but if your just doing it to upgrade stock suspension for daily driving then i'd go with just the plain lakewood panhard and LCA's with poly bushings (cheapest ones i could find; good quality)a new set of shocks wouldn't hurt either, i've found this set up plus lakewood 50/50 drag shocks and the eibach prokit (1.6" lowering springs) to be very streetable as well as beneficial at the track just my $.02
brandon
Old Jun 9, 2004 | 01:07 PM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
i got the sphon LCA's and panhard they make a world of difference
Old Jun 9, 2004 | 01:55 PM
copperhead110's Avatar
No matter what components you get, try and get them from the same source. BMR, sphon, lakewood and others are good, but mixing and matching vender components may negate some of your gains.
Polyurathane busings for the front end and new parts may be good too.
Old Jun 9, 2004 | 02:55 PM
FLYNLOW92rs's Avatar
Each vendor has their speciality.....
I think getting an entire suspension from one vendor is a bad choice, think individually about who makes the best product for specific application and go with them
Choosing a vendor for SFC's simply becuase you already have their STB and wonderbar is not a logical way of thinking.....or vice versa
For my plans, no two parts are from the same vendor, each part was picked for quality, not for name brand..
Old Jun 9, 2004 | 03:21 PM
High quality parts from multiple people is not a bad choice either.
I would think the bottom line is planning and research.
Make sure you make a well informed choice. Searching this site is a good spot to start.
I probably should have said "consider one vendor".
Old Jun 9, 2004 | 05:59 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
for the tower brace i was thinking hotchkis, for the shocks and coils i was thinking konior qa1, torque arm bushing energy suspension, for springs eibach, panhard spohn, and trailing arms hotchkis, what do u think?
Old Jun 9, 2004 | 08:13 PM
Spdfrk1990's Avatar
Ide go spohn sfc's,spohn,lca's and panhard,global west delalum bushings,eibach springs,bilstein shocks,TDS wonderbar,tds ws6 sways if u dont have any,TDS sway bar mount bushings,Energy suspension endlinks,Edelbrock 3 point STB bar unless spohn releases a nice one.
Old Jun 9, 2004 | 09:22 PM
CaysE's Avatar
Spohn subframe connectors; no competition.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
