Ronal R15
Old Jun 14, 2004 | 07:43 PM
Rezz's Avatar
Car: Conv RS & Formula Firebird
Ronal R15
I mounted my Ronal R15 wheels for the first time today on a 1991 Camaro Conver RS. Rears went great but the fronts are ever so slightly touching the tie rod ends. Any suggestions as to what type of spacer I need for a 1991 Camaro?
Thanks Renzo
Old Jun 14, 2004 | 07:47 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
If the supplied spacer isnt enough, you can either grind a little bit off the tie rod for clearance or see if a Mr. Gasket 7/16" spacer will give sufficent clearence.
Old Jun 14, 2004 | 07:59 PM
Rezz's Avatar
Thanks Justin, Spacers did not come with the Ronals I bought them from a guy that had never mounted them but had purchased them for a Firebird. I'll Give your suggestion a try. Thanks again!!
Old Jun 14, 2004 | 10:34 PM
You could put on 1LE brakes then you wouldn't need any spacers
Old Jun 14, 2004 | 11:19 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
go grab some spacers off a drum car in the boneyard and you should be set
Old Jun 15, 2004 | 06:05 AM
Rezz's Avatar
Justin:
Does the 1 LE brake kit for the fronts push the front wheels out because of a different dimension on the rotor assembly?
Renzo
Old Jun 15, 2004 | 10:32 AM
nolanr0413's Avatar
Car: Trans am
those rims were supposed to come with 1/4 inch spacers.
Old Jun 15, 2004 | 11:33 AM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
Yes
Old Jun 15, 2004 | 02:37 PM
Rezz's Avatar
I spoke with the Ronal Rep today. Although the wheels are no longer manufactured they continue to manufacture the spacers and special lug nuts that have longer shanks to allow passage throught the wheel mounting holes and finaly to the Spacer. I have ordered the spaces from him but the catch is that some wheels were manufactured with mounting holes large enough to pass the longer lug nuts while others were not. We do not know which wheels I have even by looking at the casting number behind. Given that no spacers wre supplied with the wheels I have, it is most likely that I will need to do some adidtional work. See Its a crap shoot, if the lugs work fine great, if not, he tells me I will need to have the mounting holes on the wheels inlarged by having them drilled out an additional 1/16 inch in diameter. I luv the look of these wheels but its no cheep upgrade. Oh well you know what they say, "you wanna play you gonna pay".
Old Jun 15, 2004 | 05:50 PM
Axoid's Avatar
Car: 92 Camaro RS
I measured the stud hole on one of my R15's. The hole is about 5/8ths (.607) of an inch. The diameter of the nut shank is .603. Good luck.
Old Jun 15, 2004 | 07:50 PM
You could always use longer studs.
Old Jun 16, 2004 | 05:05 PM
Rezz's Avatar
Thanks guys. Well I should get the spacers and the wheel nuts in the next day or so. Will post a picture or two when its done.
Renzo
Old Jul 5, 2004 | 03:04 PM
Rezz's Avatar
Ronals on board. Thanks for the help. Heres a pic.
Gary@Ronal
Apr 16, 2008 11:34 PM
Gary@Ronal
Mar 16, 2003 10:01 PM
formula91
Aug 17, 2002 01:34 PM
Gary@Ronal
Jun 25, 2002 03:03 PM
