Lowering?
Old Jun 15, 2004 | 01:34 PM
snipcod's Avatar
Car: 1984 z28 Camaro
Lowering?
How much would oyu lower your camaro. I seen a few options on how much you can drop them. From 1.0", 1.3" 1.8" below stock ride height. What do you think would be best?
Old Jun 15, 2004 | 02:27 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
For most people I would say go with about a 1in drop...it the rest of your suspension and you really want to go lower then you can go up to about 2in.
Old Jun 15, 2004 | 03:03 PM
snipcod's Avatar
If i lower it 1" do i need to get Adjustable Lower Control Arms? Or will a reg Lower Control arm work? But I would need to get an Adjustable Panhard Bar right.
Old Jun 15, 2004 | 03:29 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
It all depends on where you drive. Mine is down 2 full inches up front (actually closer to 2.25) and about 1.75 or 2 in the rear. The only thing I drag is the air dam. My exhaust has drug, but it was in a friends dirt driveway. Any time you lower the car at all you SHOULD go with the adjustable panhard rod, but the control arms are not necessary. I am running Granetelli non-adjustable rear arms and a Spohn adjustable panhard rod in my car. The one thing you should get are the relocation brackets to correct the geometry of the rear suspension after you lower it.
Old Jun 15, 2004 | 03:55 PM
snipcod's Avatar
where can i get relocation brackets. Im looking on hawks. But dont see any thing.
Old Jun 15, 2004 | 04:17 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Spohn has them. Actually Spohn has everything you need. When looking at brackets, get the weld in ones, not the bolt-in ones. If you do go with bolt-in's, weld them in too.
Old Jun 15, 2004 | 04:38 PM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
I have Eibach pro kit springs which lowered my car a little over an inch. You also might want to get a Spohn adjustable panhard bar to center your rearend. It will move a little when you lower it. (mine did)
Old Jun 15, 2004 | 04:46 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
If you decide to go with an adjustable panhard rod, get the Spohn. The adjustment point is closer to the low end, so adjusting it is really easy, even with the car on the ground.
Old Jun 15, 2004 | 10:34 PM
JDF-Z28's Avatar
Car: 1983 Z28
Damn straight! Took about 5 minutes to adjust mine and looks great in the red powder coat.
Old Jun 16, 2004 | 08:00 AM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Amen brother! My car is so low, I have to jack it up (or drive onto my custom made ramps) to, well, jack it up! A friend has one that the adjustment point is in the middle and let me tell you, that thing is a bitch to adjust.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
MrPackstin
Oct 25, 2017 08:09 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
92projectcamaro
Sep 29, 2015 07:07 PM
