think I need a steering rebuild
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
I was driving along the other day and went to turn left and it did, but then wanted to go right. I got under the car tonight and did some pulling and the drivers side is fine, but the passengers side isn't when I pull of the tie rod or idler arm I get a good 1/4" of movement. I think its time for a rebuild, but I dont know how much movement is normal. I was going to rebuild it anyway, its just this is bad timing with my winter car acting up
lateral movement isn't so much a problem, the parts are suspose to move, vertical movement is is undesireable. if it only did it once might of beed the raod and not the car or some other factor.
Car: 92' RS
Engine: LO3
there was vertical movement, mainly on the idler arm side, not so much on the pitman arm side. I take the same road all the time so I doubt it was the road
Car: 92' RS
Engine: LO3
I am curious, that if and when I do rebuild it, what if any speciaalty tools whill I need? ie ball joint separator.
Car: 92' RS
Engine: LO3
i have a 6" bench vice,, air is not a problem, I have 2 compressors, a 5.5hp 25 gal, and a 6hp 33 gal, with an impact wrench, pneumatic wrench and a die grinder.
Still need the forks and spring compressor
oh and I have a map gas torch
bubbaz28
Sep 18, 2015 02:09 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
