Alternative to "custom hats" for 2 piece rotors
Old Jun 18, 2004 | 06:22 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Just wondering if anyone had ever thought about using a drum brake hub from a 67-69 camaro for rotor hats. Shopping arounf they go for $25. Would save in time, hassle, and money if you could use these instead of trimming down a set of stockers for a 2-piece rotor setup.
What do you guys think? Cant remeber if this has come up before.
Attached Thumbnails Alternative to "custom hats" for 2 piece rotors-camaro_disc_drum_hubs.jpg
Old Jun 18, 2004 | 07:49 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I have no idea, but I really want to know.
Old Jun 18, 2004 | 08:39 PM
The hub on the left is the drum hub. I belive it has the same offset. I don't know what size bolts those are (7/16 or 12mm?). I thought that if you are working on a daily driver, at least you wouldn't have to buy junkyard rotors to turn down.
Old Jun 19, 2004 | 02:59 PM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
I thought of this using early Chevy\Olds\Pontaiac drum brake front hubs. You can find a 5x4.75" bolt circle if you go to things like a Nova or Acadian. Unfortunately I was unable to find a matching bearing combo that woul fit onto our spindles. The outer bearing is fine ( I believe . Might be vica versa...memory foggy ) but the ID of the inner bearing is too large to fit the spindle. I spent many hours going through bearing catalogs and physically measuring things to no avail. In the end it was much easier to simply machine down a set of used 1LE rotors.
Old Jun 19, 2004 | 06:05 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I was looking into them when I was working on the C4 and LS1 swaps. I was unable to find their offset, bearing sizes, stud size, and stud pattern. So I just went with turning down thirdgen rotors. Also the turned down rotor seems more beefy and thicker then the 1’st gen hub.
Old Jun 20, 2004 | 07:06 PM
Ah hah.....You guys just don't miss a beat.
Right on. Thanks for the info.
Frozer!!!
Jan 19, 2024 04:55 PM
Cornholio7979
Sep 20, 2018 02:31 AM
deracer
Apr 11, 2016 12:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
