brakes pull
k hese what you do
just so you know i am ase cert. in brakes, so you can trust this
Rebleed all lines get some one to pump the brakes 3 times then then release bleeder and close it before all the pressure is released to assure no air is pulled back in to the system, do this about about 3 to 4 times per wheel,
Make sure Right front caliper is sliding ok not stuck take it off and inspec the sliding mechinizum ( spelling ) if it is not sliding lube it with some lituim grease or antiseize lube. be librail but dont get any on the rotors or pads.
Also make sure the Piston is not stuck, grab a pair of slip joint or water pump plyers , or a C-Clamp for thta matterwhich ever you know them by and push the piston in if you can if you can't, replace the caliper better to replace them in pairs.
Bes ure that there is no grease or brake fluid/ oil on you front rotors or pads if the is wash it off the rotors and spray them down with brake clean, if it is on the pads also replace them it will not be able to be washed out
just be sure everthing is tight after you have done this and test drive. should be solved, never met one i could not solve, vcould also have to do with the master clylider but not likly.
sorry this is just how i remember it dont mean to make you feel bad ( like not knowing how to bleed your brakes or anything just how i was taught and it is imprinted in my head, everyone has their own ways, this just works the best for most)
Be best to just do this to both sides have seen it where the left want working right and pulled right or the pass side wasnt right and pulled right.
good luck any other question shout at me
Travis
Travis
