Ever consider ceramic brake pads? I did... (picture)
Old Jun 26, 2004 | 10:07 PM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Axle/Gears: 4.11 12bolt
I might not ever buy ceramic brake pads again. See picture below.
Both inner pads seperated!!!
Attached Thumbnails Ever consider ceramic brake pads? I did... (picture)-brakes_web.jpg
Old Jun 26, 2004 | 10:41 PM
Spdfrk1990's Avatar
Cant see the pic and what brand did you buy.
Old Jun 26, 2004 | 10:46 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Did you "brake" them in properly and bed the pads in properly?
Old Jun 27, 2004 | 01:16 AM
25THRSS's Avatar
Wouldn't matter anyways, they should not do that under any circumstances.
Old Jun 27, 2004 | 01:37 AM
Kandied91z's Avatar
wow...what brand. i'd take them back.
Old Jun 27, 2004 | 01:40 AM
25THRSS's Avatar
Doubt it has anything to do with it being ceramic, but more a quality control issue with the manufacturer.
Old Jun 27, 2004 | 01:44 AM
TwinTurboROC's Avatar
being ceramic had nothing to do with that... its the bonding of the friction material to the backing that seperated... take that back, and get a refund... nothing else got destroyed?
Old Jun 27, 2004 | 03:19 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
id dont care how strong of glue it is, i wouldnt want it on anything to do with my brakes
Old Jun 27, 2004 | 06:53 AM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
AIMCO pads, and I found them like this on Saturday, 2 days after I had my car state inspected, and passed?!?!?!
I don't have the original box but have the receipt and will be taking them back today.
I'm just wondering how long they were like this.
I'm also going to put on new rotors they look like they got chewed up a little.
Old Jun 27, 2004 | 02:39 PM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Well I got new rotors and new pads at no charge. =)
I hope this set doesn't seperate, I guess I'll have to check them often, =).
After I wear these down I get another set at no charge, =).
later
Old Jun 27, 2004 | 04:33 PM
kevinc's Avatar
Car: 1982 Z28
Wow, that's a mess. I'd hold off condemning all ceramic pads over this, even if your replacement Aimco pieces fail.
I beat the snot out of a set of Raybestos QS ceramics at Pocono 2x and Indy, they overheated and the friction surfaces got cratered, but they didn't separate from the backing plate.
Old Jun 27, 2004 | 07:15 PM
Spdfrk1990's Avatar
Thats cause ceramix isnt a performance pad its a great street pad. They build up to much heat on the surface of the pad under alot of hard stops. They have the shortest stopping distance but if you keep putting the hard stops to them they are gonna over heat.
Old Jun 27, 2004 | 10:57 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
i have ceramic bosch brand pads never had a problem with them besides being very aggressive on my rotor.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
g.l.mos
Aug 22, 2015 12:02 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
kyleb24
Aug 15, 2015 08:24 AM
