10 bolt drum to 12 bolt swap
Old Jun 30, 2004 | 05:12 PM
camaro_60181's Avatar
Car: 1986 Iroc z28
I'm getting a 12 bolt disc custom rear for a f body for free. My question is what would I need to do the swap. Ie: Do I have to swap master cylander? Proportioning valves? Break lines? any thing else I'm missing???
Thanks in advance for all help
Old Jul 2, 2004 | 07:12 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
You'll need new sway bar mounts to fit the larger diameter tubes. I'm also pretty sure that the stock drum break setup will not work, but not 100% positive.
Old Jul 4, 2004 | 10:05 PM
Car: 1986 Iroc z28
I want to convert to disc....
Old Jul 5, 2004 | 09:18 PM
Engine: LO3;383tpi
.......ok
then in that case do a search on the numerous posts that have already been done on swapping to disks.......
Old Jul 6, 2004 | 05:37 PM
twistedwedge's Avatar
Car: 87 GTA
Engine: 355 Chevy
i did the same swap..used a wildwood adj. valve for the rear brakes. havent had any probs. yet and its been a year since the swap.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
355tpipickup
Aug 25, 2015 12:54 AM
