billet strut mounts
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
They shouldn't add any noise as they don't move, and shouldn't vibrate at all.
Ed
Ed
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
I keep wiping out bearings. Though Karl and others claim to never have. Funny thing is that my car is also lighter weight up front than most others, however I do run the Koni's very stiff. Last set Iof bearing I put in were the Aurora PRN-12's. They lasted about 8 months until play- the standard COM-12's they came with went bad on me within weeks.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I've had mine on for about a year now, no bearing problems.
and no noticable noise or vibration.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you might want to mic the insides and see if they're still round... how much camber are you running?
Car: '87 Cam RS V6
Engine: Top Secret
Originally posted by MrDude_1
on both of them or just one?
The front camber on this car is aprox -.80, but that has nothing to do with the problem. The problem I'm having is the high dampen force I run the Koni's on to handle the 800+coils. I run them 1/2 turn from max rebound. That combined with the way I abuse this car on rough street roads is why they don't last. Its not the mounts, its the bearings (Just like any spherical bearing run on street cars- race tracks for the most part don't have bumps, dips, and potholes like street driving does.)
Car: '87 Cam RS V6
Engine: Top Secret
Another note: Dale (Jay) metioned to me in an email awhile back that QA1 makes a very high end spherical bearing that has a much greater load rating than even the Aurora ones I used last. I will have to check on them next. These last ones were not cheap (PNB-12T's are aprox $60 each/ COM-12T's are only $16 each)
The QA1 bearings Dale was telling me about are NOT the ones used in the Spohn mounts, the are supposed to be much hgier load ratings- I'll check and see right now if I can locate any such info.
Car: '87 Cam RS V6
Engine: Top Secret
Stangski09
Nov 14, 2015 01:27 PM
rb85TA
26
Sep 14, 2015 10:29 PM
