Roll Cage
Old Jul 5, 2004 | 10:28 AM
lancerracer's Avatar
Car: 1988 T/A WS6
Engine: none right now
Roll Cage
I am trying to tie up the chassis on my 88t/a, and I am thinking of installing a roll cage. I am trying to get some protection and trying to stiffen up the chassis. Do the Roll cages witrh removable side bars offer the same benefit as the cages with permanant bars? Also, does anybody have pics of the side bars on the sw racing roll cage? Thanks
Old Jul 6, 2004 | 05:43 PM
twistedwedge's Avatar
Car: 87 GTA
Engine: 355 Chevy
I dont like the removable side bar cages...There has to be a strength issue there in relation to rigidity.
I have a 6pt rollbar in my 'bird. The first time I drove the car there was a noticeable difference in stiffness. Also the first time I lifted the car up with a floor jack I put the jack in the same spot as usual and instead of just lifting the front side of the car it lifted the rear tire off the ground as well. If you are planning on doing any type of racing with the car I would reccommend at least a 6pt.
Old Jul 6, 2004 | 08:08 PM
Car: 1988 T/A WS6
IS the sw 8pt from spohn with the side bars that clear the door handles legal?
Old Jul 7, 2004 | 05:16 PM
Car: 87 GTA
Engine: 355 Chevy
I dont think that removable sidebars are NHRA legal, but I might be wrong. Far as the 8pt question I would get with Steve Spohn on that one.
Old Jul 7, 2004 | 06:51 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
my car when jacked up will lift the rear tire up also... with out a cage.... just letting you know man
Old Jul 7, 2004 | 07:03 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Any car will lift both wheels if you jack it in the right place, usually right under the middle of the door (for 2-door cars.) The real test is to jack it just slightly behind the front wheel and see if it picks the back up also.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
FueledSoul
Sep 30, 2015 09:18 PM
FormulaEngland
Sep 30, 2015 01:50 PM
tmork454
Sep 29, 2015 06:33 PM
