4TH Generation Front End
Old Jul 7, 2004 | 03:08 PM
caprice_90's Avatar
Car: 86 TRANS AM
Engine: 350 CARB
I have an 86 T/A with rims from a 99 Firebird (16"). Right now I have spacers on them so that they will fit. I am going to swap out the 3rd Gen Rearend for a 4th Gen rearend since it will bolt right up. My question is will the front end (A-arm, calipers, spindles, steering parts, etc.) from a 4th Gen bolt up to a 3rd Gen T/A? I would like to get rid of my spacers as I am worried about bearing wear. Does anyone have any info?
Old Jul 7, 2004 | 03:11 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you cut off the front subframe assembly of your car
get a 4thgen front subframe assembly
weld it on just right
create mounting brackets for the 3rdgen fenders, lights, ect...
then, sure... you can bolt the fourthgen front suspension on...
and dont laugh... Fatal88 already did it.
Old Jul 7, 2004 | 03:26 PM
FLYNLOW92rs's Avatar
Yup, really deep pockets and very good skill is all you need....
Fatal88.........The ultimate thirdgen when it comes to 4th Gen parts being modified to fit a thirdgen.........:hail:
Old Jul 7, 2004 | 04:34 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
yeah, here is a shot of his front rim from the houston gathering.
Old Aug 13, 2004 | 09:55 PM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
bearing wear
if you bought the correct adapters you will not experience any bearing wear. the adapters give your 4th gen wheels the correct offset for the 3rd gen car. I also have 4th gen wheels on my 3rd gen Z and have not had any problems. I plan on doing the 4th gen rear end swap but I will leave my 3rd gen front end alone, except for the tubular k member and A arms.
Old Aug 14, 2004 | 12:04 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
what kind adapters do you have on your thirdgen?? Im planing on getting some Zo6 wheels. will the ones from hawks work??? I dont bearing wear.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
