getting tie rods to connect to centerlink
Old Jul 13, 2004 | 11:55 AM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
how the hell do i get the damn things to go back into that hole?! the puller tool i bought wont work the other way around
Old Jul 13, 2004 | 12:03 PM
91Z28-350's Avatar
You stick it in the hole, tighten the nut to torque specs (40 ft-lbs) and stick a cotter pin in it. If the holes don't line up, tighten it some more until it does (exceeding 40 ft-lb torque). Never back off to align the hole and the castellated nut.
Is there something I'm missing?
Old Jul 13, 2004 | 12:18 PM
i cant tighten the bolts if they dont go thoughthe centerlink
Old Jul 13, 2004 | 12:23 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Well... why aren't they going through the hole? Are they not lined up right, or is the threaded section of the joint too big? If you are having an issue with the correct postion just turn the steering a little to get them to line up! If the hole is the wrong size then I would guess you were given the wrong part. I can't see any other reason why it wont go back together, unless you are accidently trying to put it back together incorrectly!
Old Jul 13, 2004 | 12:33 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Did you by any chance just install a new centerlink? If so, it may be on 'backwards' and have the tapered hole facing the wrong direction. It should be 'curved' towards the crossmember.
Pete
Old Jul 13, 2004 | 01:31 PM
Pete
yep.... thats what i did
Old Jul 13, 2004 | 05:16 PM
I'm good.
Sorry.....
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
TOMcat GTA
Sep 15, 2015 09:31 AM
Street Lethal
Sep 7, 2015 01:09 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
