Need to replace front wheel studs
Old Jul 14, 2004 | 11:48 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I have one broken and one stripped stud on my right front wheel. How difficult is it to replace them and what is involved?
Old Jul 14, 2004 | 11:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Unmount the rotor, press out the old stud with a large socket and C clamp, insert the new one through the back, slip a stack of washers on the front and use the lug nut to pull it all the way through.
Old Jul 15, 2004 | 12:16 AM
RSFreak's Avatar
Sounds easy enough. Where can I buy wheel studs? Does Schucks stock them?
Old Jul 15, 2004 | 12:21 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Pretty much any parts store should have them or at least be able to get them.
Old Jul 15, 2004 | 02:40 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
I could not get mine out ....so I took the rotor up to PepBoys and had them press it out and press a new one in....$5
Old Jul 16, 2004 | 12:20 AM
Belker's Avatar
I broke one of my front studs taking off a lug nut. It was really easy to change. I hit it with a hammer and it popped right out. I though I was gonna have to beat it out, but it came right out on the first hit. Installation of a new one was almost as easy. I simply tapped it in with a hammer making sure that it went in really straight.
B_Dubya
Aug 26, 2015 05:09 PM
TheExaminer
Aug 25, 2015 07:34 PM
kah992
Aug 19, 2015 02:55 PM
wruiz
Aug 11, 2015 02:59 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
