Noise after Adj. Torque and LCA brackets
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hi....
I have some new noise in my car after I installed some new parts.
1. It sound and feels almost like my rear trans mount is off when it shifts 1-2 but the mount is new with a Spohn Adj torque arm.
2. When driving I can hear something "grinding", sound like a gearing sound.
Here is what I've done.
Mounted adj.spohn torque arm and some LCA brackets, my guess it the rear end geometry isnt 100% correct and some angle is wrong somewhere.
How can I check that the rear axle is in its place? where to measure?
The Pinion angle is set to 0 deg.
Also I got two trans mount with my spohn torque arm, Maybe I should install the other one and try, for you guys who has the spohn arm+TH700 what part.nbt is your rear mount?
/N.
/N.
armybyrd
Sep 15, 2015 06:06 PM
