who has 9.5 rims with 5.5 bs and a tire larger than 275
i want to put a tire larger than 275 on the rear. Im getting boyd coddington rims with 5.5 bs and they are 9.5 inches wide. Does anyone have like a 285 or 295 on a 9.5 inch rim and no have rubbing problems.
you should be alright up to a 295 depending on the profile and height of your car. your cutting close but you could do it.....no air ride though or extreme lowering without some quarter rolling.
crap , i was thinking about lowering the car some more in the rear or doing the air ride thing. O well, maybe ill see how it looks once i get the rims as to if im gonna lower the car more. thanks.
does anyone have any pics of what a 285 or 295 looks like on a 9.5 inch rim with 5.5 inch bs. I dont wanna go and order these tires and have them rub and be out 600 bucks.
just look for a 285 or 295 tire. your basically putting a wider tire then necessary for the rim so not only do you have to watch the profile but your going to get that bulge you get with non sports profile tires. this will cause sloppy turning as well as give you more rubbing issues since the tire can move more.
what's the point of going slightly larger anyhow when 275 is the right width for a 9.5" rim? just measure out your offset so it's correct. companies now even sell wheel kits which let you mock up a wheel so there is no confusion. put the right size tire on it and then you can do whatever you want with the car with no problems.
as far as 295 tires.....just about all the companies make them. mine are bfg drag radials. i run 285/35/18 toyos on the street.
the 295's are in this picture.....so it's possible if you do the right measurements.
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
kandied91z,
would a 275 size tire fit fine on a 9" rim cause the rims I am getting are only 9" wide.
Sorry nolan for highjacking your thread.
yep, choose your profile wisely and no one will tell. a 265 is better suited though.
245 is for 8" and it goes up 10 a width for every .5" wide a rim. of course you don't have to follow this rule but if you do things will work out best in the end.
whoops, meant 10 so an 8.5 would be 255...etc.
very nice picture, look how much your stretching them in that picture....here in michigan your rim wouldn't last a weekend cruise.
personally i like the square tire but if you like the rounded edges like that running a narrow tire would work. alot of combinations can be made to get the ride width while using a different profile to adjust for the overall look as well as protect the rim.
Ok, i get your point. But if i am afraid of scratches on my rims i run the 215/65 15 on the 7 inch rim setup... I just mean, a lot of people in this forum want to reduce weight and increase power and performance. Take a look at the BMW M3 CSL - Exactly the same philosophy. And take a look at the rear of the car, 265's on a 10 inch rim.
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
Originally posted by Graboid
found an ooold pic of my camaro. I had 9.5 inch wide rims wrapped in 255/45 17's. Perfect combination, if you ask me. Tells you how a 275 on a 9 inch rim might look.....totally wrong
Car: 1991 Camaro Z28 Clone
Engine: 350 w/TBI
Transmission: WC T-5
Axle/Gears: Spicer 3:73 Auburn Posi
here is a pic of my car when i first bought it "sh*ty i know" and it had 295/45/15's on it... the rims were 8.5"s wide....
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
i have 17X9.5 on 275/40 on my rears. A friend that sold me the rims forgot the off-sets on my rims. But he told me there 4th gen rim with a thirdgen off-set
Engine: 350 w/TBI
No wonder thirdgen f-bodies have a white thrash reputation.......
Yeah i know what you mean... that pic was from the day i bought it., and this is why i saved it from "them". Car is currently under restoration, and looks likes this...Sorry, didnt want to hijack post or anything, but i also didnt want someone thinking i was "white trash"
and made my car like this. those rims came off about a week after i bought it... Thread
Hotrodboba400
Dec 10, 2019 07:07 PM
rb85TA
26
Sep 14, 2015 10:29 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
