Big THUMP
Old Jul 18, 2004 | 10:09 AM
86FBirdL98's Avatar
Car: 1986 Pontiac Firebird
Big THUMP
Whenever I take off from a stop and give the throttle anymore than a little easy tap(i.e. give it quater throttle) i feel this huge thump before it gets traction. It doesn't feel like wheel hop either because it's only one loud thump not a series of small thumps. It even shook the center console glove compartment lid loose one time. Any idea what is causing this?
Old Jul 18, 2004 | 10:15 AM
Desert86Roc's Avatar
You probably have a broken transmission mount. Get yourself a good poly mount and it wont break again.
Old Jul 18, 2004 | 02:40 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I second this motion.
Old Jul 18, 2004 | 02:51 PM
Kandied91z's Avatar
if it's a stock motor i'd stick to rubber....you can tear an poly just as easy as rubber with the right power but the vibration is night and day. unless you need it it's nice to not feel every bit through poly mounts.
Old Jul 18, 2004 | 05:52 PM
5.0Camaro's Avatar
Car: 1991 camaro Z28
well i tore 2 in a year period with my basicly stock camaro(just exhaust) and i went to a poly one and its been fine since. Plus i've never realy notice any more vibration between rubber or poly, and that is between my camaro and trans am.
Old Jul 18, 2004 | 06:52 PM
camaro of solar's Avatar
ill quad the motion that its a tranyn mount...also check your sway bar end links...i have worked on a few 92 RS's (mine included) and they all seem to have needed those...and they contribute to the THUNK sound that a tranny mound can make....
Old Jul 19, 2004 | 12:58 AM
Kandied91z's Avatar
as far as the mount....everyone drives different, if your the type that's always in the gas from a dead stop then go poly. even they can rip. i refrain from any hard launches except for the track and haven't had a problem since with alot more horsepower then when i was younger and always on the gas.
Old Jul 19, 2004 | 09:58 AM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
I'm a 36 yo who's always on the gas. You must be older than me...
Old Jul 19, 2004 | 02:33 PM
Kandied91z's Avatar
$900 for just the rear two tires you'll learn quick to lay off the gas on starts.
Old Jul 19, 2004 | 02:43 PM
88firebird's Avatar
Car: 89 GTA (88 Firebird V6 to V8 conversion RIP)
Transmission: 5 spd
Re: Big THUMP
Tranny mount for sure... I had the exact same thing happen with my 2.8 Firebird a couple years ago... its a pretty easy and cheap thing to fix... I also had the sway bar link problem on my car at one time too, but it didn't sound or feel nearly as bad as the tranny mount...
Old Jul 19, 2004 | 05:03 PM
86FBirdL98's Avatar
i never get on the gas hard from a stop, well maybe once in a blue moon. But's its not even like i have to give it that much gas to either get that loud thump, or burn out Thanks for the input tho guys, when i get the trans serviced soon I'll have the mount replaced/ checked out.
Old Jul 19, 2004 | 07:46 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Broken tranny mount. Get the Energy Suspension version. It is far superior to the stock rubber one. It is cake to replace it yourself using just a floor jack and jack stands. You'll need to open up the slot in the tranny support to accomodate the larger center bolt that ES supplies.
Kandied91Z, was it the ES brand that you used? You DID use the pre-load plate (as it mentions in the instruction sit is NOT a spacer, you MUST use it). Also you had the rounded portion facing the rear, right?
Lon
Old Jul 20, 2004 | 01:57 AM
Kandied91z's Avatar
for the poly...yes. i'm still running those now. they last about a season or two if i'm lucky.
as for the mount, if it is broken try to get it fixed soon....it can cause more damage if left alone.
Old Jul 20, 2004 | 06:37 PM
86FBirdL98's Avatar
True the last thing i want is to mess up my trans it's only a year and a half old........
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
dusterbd
Sep 29, 2015 08:40 AM
