Difference between 3rd and 4th gen E-Brake Assemblies
Old Jul 24, 2004 | 12:13 PM
coolguywalt's Avatar
Car: 89 Turbo Trans Am, '14 Forester XT
Engine: 3.8 Turbo V6
Transmission: 2004-R
Does anyone know if the 4th gen e-brake assembly will bolt right into a 3rd gen, as far as bolt holes lining up? I am doing an LS1 rear brake swap and Roy from ThirdGenResource said that is what he did on his 91 LS1 transplant. He also said the bracket under the car he welded onto the 3rd gen tunnel and they worked fine.
Old Jul 24, 2004 | 02:05 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Sorry to burst your bubble but no, at least not with the LS1 rear brakes. The '93-97 brakes are a direct bolt up but not the LS1s. Look in the Tech Articles for a couple how-tos on the LS1 rear discs and talk to guys like Dyno Don who have installed them. It's not a bolt on thing with those, sorry.
Ed
Old Jul 24, 2004 | 04:08 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Ed
Ed, I think he is just asking if he can use the 4th gen ebrake assy and bracket underneath the tranny tunnel.... I think he knows that the LS1 rear brakes won't just bolt on!
Old Jul 24, 2004 | 05:54 PM
ebmiller88's Avatar
OH, my mistake...
Ed
Old Jul 24, 2004 | 06:34 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
yes, you can use the brakets that are on the tunnel, but the cables will come up about a foot short. i went to the hardware store and bought some cable crimps and a few feet of cable. it my not be the safest set up, but its worked so far
Old Jul 24, 2004 | 11:46 PM
Well, the plan was to find out if the 98+ Parking Brake Assembly in the car would bolt up, then get the piece that bolts up under the car for the lines that pull on the drum brake inside the rotor and weld that piece up under the car at the right spot where it would work correctly. You say that the lines are about a foot short....guess I am definately going to have to weld SOMETHING!!!!
Old Jul 25, 2004 | 12:44 AM
ebmiller88's Avatar
Search for posts by Dyno Don, he posted pics of the bracket he made to make his work.
Ed
Old Jul 25, 2004 | 01:57 AM
I have already spoken with Dyno Don and he said that the braket he made he can make again for me and send it to me for like 25 bucks or so, I am really just looking to see if the 98+ F-body Parking Brake handle Assembly can be bolted into the 82-92 F-body without any modifications.
Old Jul 25, 2004 | 09:38 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
No it can't, I already tried that.
Old Jul 25, 2004 | 11:13 AM
Well, on the camaroz28.com board, some of the guys have swapped ls1 rears in and said that the lt1 E-brake handle was fine and they had no problems with it. My question now is: "Can I use the 93-97 E-brake assembly in my 3rd gen?" Someone said somewhere that is bolted right up......
Old Jul 25, 2004 | 11:54 AM
Dyno Don's Avatar
E-brake
Well I have both and they are about 1" longer than a 3rd gen.
It will bolt in but you can't shrink the cable, so it won't hook up .....because it is too long.
Old Jul 25, 2004 | 12:07 PM
Well, how exactly did you get your e-brake cable to work? I PMed you about the bracket, but what else is really needed to get these things to work?
Old Jul 26, 2004 | 05:15 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
We used some GM cables for 91 or 92 Camaro with disc rear end with the loop style end, not the ball style. We had to enlarge the hole a bit to get the loop to fit around the LS1 ebrake arm. After it was enlargened, it bolted up perfect and works great.
I've been informed that that cable is discontinued though and Napa carries a replacement but I haven't been there to see what they have.
These might be the part numbers:
10136875
10136876
1992rs/ss
Jan 31, 2025 05:10 PM
Fast355
Dec 2, 2016 06:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
