Panhard Rod brace bushing
Old Jul 24, 2004 | 02:22 PM
3gc's Avatar
3gc
Car: Z28
I installed a new cat back yesterday on my car and noticed that the bushing for my panhard rod brace is very warn, i can twist it and move it by just using my hand. Does anyone sell a new bushing for it or should i just get a new brace from GM? Gmpartsirect has it for $37 shipped. And if i do go the route of getting a new brace could anybody confirm that it comes with the bushing?
Old Jul 24, 2004 | 06:34 PM
MdFormula350's Avatar
http://www.spohn.net/product.cfm?productid=1361
Old Jul 24, 2004 | 09:36 PM
MartinCadek's Avatar
I believe he was referring to "panhard brace", not the actual panhard bar, what you linked to would be absolutely useless in this case unless the bushings are the same size which they very well may be.
Old Jul 24, 2004 | 10:44 PM
3gc's Avatar
3gc
Car: Z28
I never thought that they would be the same. I'll have to take a look and some measurements tommorrow or monday. If not i'll order a new brace from GM.
Old Jul 25, 2004 | 12:32 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Any of the braces I've seen didn't have any bushing at all, just a tube for the bolt to slide through and keep the mounting brackets from collapsing when that bolt is tightened up.
The tube was about the same size and thickness as that inside the bushing in the panhard bar, but it's just welded into the end of the brace.
Old Jul 25, 2004 | 02:37 PM
yeah i didnt think that the brace had a bushing thats why i thought maybe it was the panhard bar he was talking about.
i would figure if it does have bushings then it would be the same.
Old Jul 25, 2004 | 05:03 PM
3gc's Avatar
3gc
Car: Z28
Ok, guess i was wrong heh. Since there's slop in it i assumed there was a bushing that deteriorated. I'll try and tighten it some to see if that solves the problem, if not i'll find a used one or just order a new one.
Old Jul 25, 2004 | 07:12 PM
3gc's Avatar
3gc
Car: Z28
Well tightening it solved the problem, Got rid of a driving noise at the same time which made me happy. I should of started with the easiest possible causes first. Thanks for the replies.
Old Jul 26, 2004 | 12:49 AM
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
