how to bleed the 1LE's?
Old Aug 10, 2004 | 06:32 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
Im installing braded lines & new calipers all way round. & Ive never blead a system before.
1. What tools do I need & what are the best systems for this job.
2. Can someone tell me step by step how to do it.
3. I want to get rid of all the old fluid while Im in the proses.
4. How do I make shure I dont have water in the lines, they have been disconected for a couple of days and its been raining non stop. (Ive heard that brake fluid sucks moisture)
If you guys can think of something that I might have forgoten or probably dont know, that might help my lerning let me know.
Old Aug 10, 2004 | 06:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The minimum tools you need are a wrench (preferrably a flare wrench) and a friend.
If your old fluid is nasty and gross, you can start by gravity bleeding, open all the bleeders slightly and let the fluid dribble out. Keep topping up the level in the master cylinder reservoir so you don't let it run dry. As you start seeing nice clean fluid coming out of the bleeders, you can close them, and then bleed them in sequence, starting with the wheel farthest from the master cylinder and working to the closest. Open the bleeder on the corner you're working on and have your friend depress the pedal. When the pedal is fully depressed, close the bleeder and have them release the pedal. Repeat until no air bubbles out of the bleeder while it's open. Again, make sure you don't let the reservoir run dry. Air in the master cylinder is a Bad Thing.
Unless your master cylinder has been open and collecting rain, don't worry about water in the system. Brake fluid is supposed to absorb moisture, to prevent water from collecting in the system and causing corrosion.
Old Aug 12, 2004 | 05:15 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
The car needs to be on?
Old Aug 12, 2004 | 05:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Car needs to be off.
Old Aug 12, 2004 | 05:34 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
One last thing... Whats the best brake fluid in your opinion?
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
84redta
Sep 19, 2015 09:58 AM
dimented24x7
Sep 6, 2015 03:51 PM
