will iroc springs lower?
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
will iroc springs lower the ride height of a z28?iroc springs are from a 87 the z is a 85.is there a difference between the springs?
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
yep, theres a difference they are worn out a bit less then yours, spend the money and get some good lowering springs
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
If your springs were brand new and the IROC springs are brand new then it would lower it slightly...less then an inch though. But if the IROC springs are new...they'll probably raise your car considering your springs are probably pretty sagged and old. I'd suggest getting a Eibach Prokit for your car. Not to much of a drop but the performance gains are good.
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
the springs in my car are fine...these are a set i have that a friend of mine wants for his z28.i told him i thought they would lower his car a bit but i just wanted to check before i sold them to him.are the iroc springs better than the z28 or are they the same.
ambainb
Apr 25, 2016 09:21 PM
sailtexas186548
Aug 26, 2015 03:32 PM
mustangman65_79
Aug 11, 2015 03:17 PM
