Hmmm weird noise when turning..
Old Sep 10, 2004 | 05:00 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Okay, I don't know if this is suspension related or drivetrain related as I haven't really inspected it much. Just noticed in the last day or two that my car whines quite a bit when making right turns. Whines a very little bit around left turns, but more-so on a right turn.
I figured it was a power steering issue but decided its not that since I can hear the power steering pump make a different and much quieter noise. Then I figured my tires may somehow be rubbing, but I don't think they are.
Could it be anything in my rear suspension at all, or even my differential? I just replaced the whole rear-end with an LS1 rear w/ 54k miles on it, and I've put maybe 1000 miles on the car since then. I'm hoping its a suspension issue and not a differential issue.
Basically, I want your input on possible causes. It is a whining noise...not a scraping noise.
Old May 20, 2005 | 04:53 PM
figdogg22's Avatar
Car: 1992 camaro rs
Transmission: auto
Did you figure it out, I got the same noise but when turning left.
Old May 20, 2005 | 07:04 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Don't rule out your power steering pump... Because that's exactly what it sounds like.
I bet your fluid is low in it.
Amazing how many people I see with this problem that just ride it out for months... And they NEVER check the fluid.
Old May 20, 2005 | 08:10 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
i have noise in my steering... but its not from the powersteering beeing low.... when i cut the wheel full lock i get a screeching sound
Old May 20, 2005 | 09:39 PM
chevymetal's Avatar
Car: 1985 Chevrolet Camaro IROC-Z28
I get that too...
I just try not to cut that hard.
Rather not hear it.
I wonder what that is...
Old May 21, 2005 | 01:13 PM
Car: 1997 Corvette
That's hte power steering pump going into pressure bypass mode or whatever its called. If I remember right, if you leave your wheel turned full lock for a while when the car is running, that can ruin your PS pump. I never did figure out what the problem was, haven't really cared much. I do have to put a bit more fluid in my PS pump, but that's not what's making the noise. I think a simple differential fluid drain and fill would fix it actually. Maybe the current stuff didn't have posi additive or something..not sure. I didn't change it when I installed this rear like I should have. I also have at least one bent axle, so that may be the problem as well. I'm currently looking for a new rearend again. Something that is already somewhat built up with 3.73-4.10s with good axles, etc.
db057
Jan 10, 2020 08:55 PM
gta892000
Aug 11, 2019 11:16 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Randomtask2
Sep 7, 2015 05:06 PM
