PROFAB Aarm users, Question, need help!
Old Sep 12, 2004 | 03:50 PM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
I just installed my tubular kmember and aarms this weekend.
Did anyone have problems with the supplied white nylon bushings and steel sleeves that came w/ the profab aarms? Did you use the stock bolts on the aarms or did you find a bigger diameter bolt? The way it is now the Aarms are pivoting on the bolts and not the nylon/steel sleeve. Is this correct?
Old Sep 13, 2004 | 05:10 PM
1983Fbody's Avatar
Engine: 415
Update- I'm currently using the stock bolts and double nutted them so the aarms could move freely without worry of having just a single nut back out. I suppose I could use a locknut if I replace the bolts, just curious what anyone else did?
Old Sep 13, 2004 | 05:44 PM
Rage13's Avatar
Car: 89 Firebird
so how do you like the parts? any problems getting them in?
i'm thinking about getting the same thing from profab
Old Sep 14, 2004 | 06:37 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I replaced all of the bolts with 1/2 13 grade 8`s I used the lock nuts with the plastic washers at the ends, with the 1/2 bolts I tourqed them down to 80 ftlbs. the steel tubes inside the nylon bushings should lock onto the frame and not twist, the bushings should move with the arm.
Old Sep 14, 2004 | 10:06 AM
1983Fbody's Avatar
Engine: 415
Rage13 I like the parts, recieved them within a week. Painted them with a three step rattle can process (silver) base/color/clear, I do some back road bombing and powder coat doesn't hold up any better than paint on gravel roads. The xmember sticks down about an 1 1/2" more than stock, and I didn't use the stock rubber snubbers for the springs so I have about 2" of ground clearance now oh well, nothing a new set of springs won't cure.
The local hardware was out of grade 8.8 12mm 1.75 bolts of the right length (for the xmember) so I had to buy longer bolts and grind 1/2" off them! Installed everything and took it for a test drive. Nothing's ever a bolt on deal for me it seems...
The frontend alignment was all whacky, Extreme toe out! I cranked the tierods closer together and it handles the same or better than it did before the install so i'm pleased.
greezemonkey Thank you, just the info I was looking for. I will install diff. bolts when I do the springs and other frontend goodies.
customblackbird
Aug 15, 2021 10:16 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
redmaroz
Aug 16, 2015 11:40 PM
