Question about front lower control arm bump stops
Old Sep 21, 2004 | 01:58 PM
Damon's Avatar
I just replaced the lower control arm bump stops on my wife's 92 RS with fresh units from the local parts store (universal replacements that fit a wide range of years with similar front suspension). These are the little rubber triangles that prevent the arm from slamming against the frame when the suspension compresses fully. The ones I took off I beleive to be original to the car and were badly cracked/split (the reason I replaced them).
The new units bolted right on but they appear to be significantly shorter than the originals. Not a lot, but probably 1/4-3/8" or so. The originals probably only had about 1/2" gap before they began to contact the frame- they were practually touching the frame just stitting and normal ride height. The new ones, being shorter, probably have about 3/4-7/8" gap from the frame.
Is there something special about 3rd gen bump stops that is different from other cars with simiar suspension with respect to their height? Should I be concerned about this height difference?
BTW- this Camaro, being a later 3rd gen, sits with the usual nose-down stance vs. earlier 3rd gens that have a more nose-up ride height. The ride height is, to my eye, "normal" for a stock 3rd gen of this vintage. It doesn't appear to have collapsed springs or anything that would jump out as being abnormal.
Old Sep 21, 2004 | 02:10 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Hum, my ES stops were deadringers for the originals. I doubt that on a car like your wife's (unless she drives much more aggressively than most), there would be any significant problems--but, of course, I'm guessing.
JamesC
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
