crooked??
Old Sep 25, 2004 | 06:43 AM
Gecz28's Avatar
Car: 88 iroc vert
crooked??
ok i installed some hotchkis suspension parts on my car and now it sits crooked? about a 1 1/2'' higher on the pass side. i put springs, lca's and panhard bar on. both doughnut things are on top of the springs. where the lca's connect to the body, the bolts are still lose. ill be pulling everything back out anyways. the panhard bar is still lose. and there is no torque arm. what would make it sit so funny?
i first installed everything and tightened it all down, and it sat wierd? i pulled it all out to take the gas tank out and to clean the under side. then when i reinstalled it all, it still sits funny?
WTF!!!???
if anyone can help, thank you!
Old Sep 25, 2004 | 09:24 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
spring indexed wrong seems most likely.
Old Sep 25, 2004 | 11:41 AM
Gecz28's Avatar
Car: 88 iroc vert
whats that mean? LOL not sittin right?
Old Sep 25, 2004 | 12:14 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Theres a little notch for the end of the spring to sit in the spring cup. It keeps the spring flushly mounted. But those are on the front, and you did rear, so.... You might want to ckeck and see that nothing is binding, or that the spring is sitting right.
Old Sep 26, 2004 | 10:13 PM
JeffW's Avatar
Engine: 305 tpi LB9
front and rear has a index spot for the end of the spring. front and rear upper has a spot in the isolator that should be lined up and the frt lower a arm has 2 holes that the end of the spring should be lined up on for index. this way the tension is in the same rate on both sides.
Old Sep 26, 2004 | 10:21 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Pics of how to index springs:
Front:
http://pg.photos.yahoo.com/ph/tarami...&.dnm=6bcf.jpg
Rear (using a 4th gen isolator but you'll get the idea):
http://pg.photos.yahoo.com/ph/tarami...&.dnm=aaf1.jpg
Ed
Old Sep 27, 2004 | 11:02 AM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
did you make sure your tire pressures were even and you are on level ground?
blue86iroc
Jan 30, 2006 12:18 PM
Frank_Blotto
Brakes
Feb 22, 2005 08:47 PM
ilikerocks
Jul 31, 2004 04:34 PM
patman_no3
Jul 26, 2003 12:15 AM
firebirdkid
Jul 8, 2003 07:20 PM
