front sway bar mounting..
Old Sep 29, 2004 | 05:05 AM
Tim Hunsinger's Avatar
Car: 91 RS,
Engine: 406ci
Axle/Gears: 2.77 9 bolt
I just put a 36mm up front, but wasn't paying attention when the old one came off. the bar dips toward the ground in the middle, and the little holes are facing the ground. Is that right or is it upsidedown, or does it matter?
Old Sep 29, 2004 | 08:56 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Don't worry about which way the small drain holes face. GM made their hollow sway bars with the holes up and others with the holes down. The bar should have the bend in the center facing down. So you've installed it correctly.
Lon
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
