Body roll :(
Old Sep 30, 2004 | 10:39 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Body roll :(
my car has some serios issues of body roll. i have put a upper sway bar and new lower bushings along with a wonder bar and everytime i corner a little sharp the tires yell at me and it feels like im gonna tip it. im not talking about fast wheel yanking corners im talking about 30 mph corners. my berlinetta had some of the same issues but that was another story,i just dont see were my big prob is.i hear alot that the f bods has great handling im just wondering were mine went. the only thing i could think of is springs because i have a v8 with v6 springs. however my buddys 92 bird with v6 springs and a v8 will out handle me corner after corner.
all suggestions welcome.
Old Oct 1, 2004 | 12:37 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
That's what I'd say....put in new Moog replacement springs or go with a set from Eibach..my cars turn on rails.
RS: KYBs with Z28 springs, 34/24mm swaybars
Iroc: KYBs with Eibach Pro kit, 36/24mm swaybars
Ed
Old Oct 1, 2004 | 10:05 AM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
Re: Body roll :(
I agree with what Ed said but I am also suspicious of this statement. Did you replace the swaybar? If so was it the front or rear swaybar? Do you know what size swaybars (Front/Rear) were on the car originally? And what size the new one is?
Old Oct 1, 2004 | 03:33 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
oopps i meant to say upper strut tower brace and new lower poly sway bar bushings.
Old Oct 1, 2004 | 03:42 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Part of it is that its an RS
Part is that its now a v8, it has weaker springs, and smaller swaybar then it should.
Another part is just flat age of the car, and some of the parts are worn out.
Alignment, when was the last one? remember adding a v8 slapped about 200 more lbs on the front, and in theory, "lowered" the car.
Old Oct 1, 2004 | 05:00 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
replace your springs/shocks/struts and your car will love you.
Old Oct 1, 2004 | 06:32 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
most likely sounds like what will be doin. i want it to ride "on rails"
Old Oct 3, 2004 | 03:24 AM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
I've got a pair of new rear Moog springs, PN 5665. $25 shipped and they're yours.
Old Oct 3, 2004 | 01:19 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I think I want those, I'll be PMing you soon...
Old Oct 3, 2004 | 03:04 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
HEY!! I need them more than you ..lol..:nono:
Old Oct 4, 2004 | 07:33 AM
Engine: 5.7, 5.0
try to get some 36mm front/24mm rear swaybars from the junkyard. Those should get rid of most body roll along with springs/shocks/struts.
Old Oct 4, 2004 | 08:33 AM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
Just make sure you get some good endlinks. The first time I drove my Z28, I wanted to take a corner a little quick and I swear the body almost rolled off the the frames...at least that's what it felt like. Got under there to check it out....and I find that I have NO endlinks....they were rusted to crap. So just make sure the endlinks are in good condition or else your sway bars won't do anything for you.
Old Oct 5, 2004 | 12:59 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
good stuff... they arent too expensive either... 14 bucks for a pair at pep boys for me..
Hotrodboba400
Dec 10, 2019 07:07 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Lanz06
Sep 14, 2015 07:16 PM
Kenwood
Sep 4, 2015 05:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
