3 point strut tower brace for a stealth ram camaro
Car: '90 Camaro RS
Engine: Aluminum Brodix-block SB 427
Transmission: Turbo 400
Axle/Gears: Moser 33 Spline 4:10
This spring i'm swapping my tpi for a stealth ram. I've heard that the stealth ram sits a little higher than the tpi. I'm looking for a 3 point strut tower brace that will fit with a stealth ram. If anyone knows what will work please let me know. thanks a lot.
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
This has come up before, and IIRC the consensus was that you have to make your own. If there's a STB on the market that clears the StealthRam, I don't know of it.
Car: '91 TA vert
Engine: turboLSx
Originally posted by Kandied91z
significantly higher...making one would be very hard and make it practicle. if you want or need a stb that intake is not for you.
Originally posted by iansane
Sh*t I learned that the hard way. Bought the HSR right after it came out, put it on and then realized I couldn't use any stb on the market.
Car: '91 TA vert
Engine: turboLSx
in order to do so you would have to have an extreme hood and some crazy angles...that or literally build it around the unit. major pita.
Code:
___ ____/ \____
Engine: 4++,350 & 305 CIs
Car: '91 TA vert
Engine: turboLSx
Originally posted by Meatman
In my opinion mini ram is just an overpriced LT1 intake.........
And the suggestion for mini ram might be good for someone who is considering both but not for someone who's already running the HSR.
Car: 1985 Iroc-Z
Transmission: t-5
one of my friends has got a custom one that guy in california made short run for people and it uses the front bolts on the strut tower than the bar runs to the front of the intake and connects on the 2 center bolts for top of the fan shroud looks pretty neat chrome. It might clear the stealth ram. and maybe that will give someone an idea on what to look at when making one.
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
The pic I'll show is off of a 1st gen Mustang, but the concept is the same. Something like this should be easy to fab up... Any ideas if it will provide the same stiffness as a traditional STB?
[EDIT] I'm referring to the 3 point brace, not the one in front of the motor [EDIT]
I think the stealth ram (While a good intake along with the LT1)
needs a little more work to make it work and fit like it should
I wonder where GM got the idea for a short runner intake????
Originally posted by Tony Walch
Maybe,until you get into a high RPM big cube motor when you need a better intake.... one that can be PORTED (without welding) to match bigger heads...
big misconception......gm had them long before tpis thought about it. even with big cubes tpis is best suited for forced induction. unless you can get one used for cheap they aren't worth the metal their cast with.
The shortest runner GM had looked like a steath ram ...and even then it was made by SLP.
don't forget they had quite a few tpi induction units that were used on test and prototype vehicles. some of which were never used because of emissions and other bs but were viewed by many.
Originally posted by TheGreatJ
The shortest runner GM had (before the LT1) came on the OLD Buick V6's, and was made by GM. Look at the late-80's fuel injected 3.8 engine (in a LeSabre for example)....the intake runner is about 3" from plenum to head flange. They just didn't use short runners on the F-body engines.....torque was considered to be more important to the F- and Y-cars, while the V6 sedans needed all the help they could get in the "highway passing-gear horsepower" department. GM had short runners before TPIS was even concieved.
The 89 TTA had some short runners also
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
Originally posted by CrazyHawaiian
There's a member on these board that made his own STB to clear his HSR. Its a blown 396 too. Cant remember who ATM ... sorry. Maybe try a search?
You mean like this?
http://community.webshots.com/photo/...90247014HLnDaR
Good info.. thanks.... but I should of stated that I was talking about the production F-body motors..
Same motor.....they just upgraded a few parts and added a turbo.
9192camaro
16
Feb 3, 2019 12:21 AM
L98GTA87
Aug 11, 2015 06:55 PM
