Fender Liners
Old Oct 14, 2004 | 05:53 PM
colonboy14's Avatar
Car: Trans Am
Fender Liners
Does anyone know if any cars came with, or how to get the fender liners that go BEHIND the metal lip? Did they come on 91-92 cars?
Old Oct 17, 2004 | 06:53 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Honestly I don't think there's a difference. If you want them to attach behind the lip, just place the liner back there and install the push retainers in, they'll work the same.
Ed
Old Oct 17, 2004 | 07:52 PM
Kandied91z's Avatar
yep, what he said....
why is this important to you?
Old Oct 17, 2004 | 08:21 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
It helps with the wheels rubbing on the fender liner. Move it to the inside of the fender and it gives the liner a bit more clearance for the tire when you are turing lock to lock.
Kat
Old Oct 17, 2004 | 11:39 PM
Morley's Avatar
Ed
Actually Ed, they won't....the holes in the plastic are huge (more precision mfg from Detroit) and the push clips won't grip them. Best bet would be to use "speed nuts" on the plastic and put it behind the metal and use screws with large fender washers.
Old Oct 18, 2004 | 05:15 AM
MIDNITERIDER's Avatar
Car: 1988 Formula 350
Transmission: 700R
Axle/Gears: 9 Bolt...3:27
Bought my car new in 1988 and had the same problem. Found an article about it and went to the dealership. There WAS a replacement liner from GM that went behind the lip IF the customer bit^hed.
Old Oct 18, 2004 | 11:11 AM
colonboy14's Avatar
Car: Trans Am
I thought there was, I just need to find if they still make it.
Old Oct 18, 2004 | 09:59 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Re: Fender Liners
Yep, they're different. Not only do they bolt behind the fender lip, they are molded differently to help stop rubbing.
Only thing I can think of is getting a set from a junk yard.
Old Oct 19, 2004 | 10:14 AM
colonboy14's Avatar
Car: Trans Am
Do you know what years they came on?
Old Oct 21, 2004 | 02:50 AM
I know 92 for sure. Maybe 91 also. If I get time this weekend, I can snap some pics of the differences between the 2.
Old Oct 21, 2004 | 08:33 AM
colonboy14's Avatar
Car: Trans Am
That would be awesome, thanks.
morrow
Jan 13, 2024 12:29 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jovibuilt
Oct 18, 2015 08:12 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
SlowAZ28
Sep 2, 2015 05:19 AM
