rear
Old Oct 26, 2004 | 08:51 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
rear
Has anybody raised the rear of there car a little so it gives the car a drag look any pic's. i have 295's 60 15's in the rear and 215 65 15's in the front and just thaugt it would look better with the back up higher or the frot lower but i dont think i could make the front lower.
Old Oct 27, 2004 | 12:32 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I cut my front coils to lower the front by 1 inch to give my car some rake. It looks really good and it's better than raising the rear. To raise the rear get a spring rubber like they use in NASCAR and put it in, it effectively increases the spring rate and will cause the car to sit a little higher, but I wouldn't do it.
Old Oct 27, 2004 | 06:06 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Sure you can...just go but a new set of rear spring isolators from GM and it'll jack it up about 1"- 1.5". Here's links to what my car looked like before and after. Good pics in the second link:
https://www.thirdgen.org/techbb2/sho...ight=isolators
and
Ed
Old Oct 31, 2004 | 10:17 PM
plumminfool's Avatar
Car: 1988 camaro sport
Engine: 355
Transmission: 5 speed
Axle/Gears: Ford 9 inch - 4.11 gears
i have air shocks on the back of my car. i can adjust the height about 4 - 6 inches.
Old Oct 31, 2004 | 11:31 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Air shocks are not a good idea, the shock mount is not built to handle that kind of loading. Running air shocks has been know to tear the shock mount out and ruin that area.
I'd cut the front springs alittle, start small and keep going till you get where you want. If the rear need a little lift, add new coil insulators.
Old Nov 1, 2004 | 12:28 AM
Car: 1987 iroc z
would you guys have any pictures what it would look like.
Old Nov 1, 2004 | 08:16 AM
ebmiller88's Avatar
Ummm...yeah...This pic is in the second link I above...did you look at it?
Ed
Attached Thumbnails rear-rear-tire-shot-1
Old Nov 1, 2004 | 04:38 PM
Car: 1987 iroc z
would you happen to have the pic of all the car.
Old Nov 1, 2004 | 04:42 PM
Mr.Crackhead's Avatar
Car: 1990 Formula
Engine: 355
Steve I know this a brd, but did you like the stance of my car when ya seen it?
Old Nov 1, 2004 | 05:36 PM
Car: 1987 iroc z
yeah it looked cool
Old Nov 1, 2004 | 05:55 PM
Engine: 355
air shocks work for me and my 12 second passes.
Old Nov 1, 2004 | 08:33 PM
ebmiller88's Avatar
Not with those isolators installed, sorry. I do have a profile of it after I reinstalled the stock ones tho.
Ed
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
