bmr torque arm installed .....problem with ride height
Old Oct 28, 2004 | 01:48 PM
xaivior's Avatar
Car: Camaro
Engine: 355
Transmission: th-350
Axle/Gears: 3.73 welded
I just installed a bmr torque arm but where the crossmember dips down to clear the exhaust i have about 2-3 inches from the ground ..hell it scrubs when i pull into my driveway ....I have a set of coil spring isolators for the rear they'er supposed to raise it up 1 inch .. but i'm not sure that will be enough ..any ideas on how to raise it alittle more? Thanks in advance
Old Oct 28, 2004 | 02:23 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Sorry but you are out of luck. Unless you are creative with fabricting skills to cut it and rebrace the support bar up over the exhaust and flat against the floorboard. The BMR design is not good on a lowered vehicle especially because of this problem.
Old Oct 28, 2004 | 02:56 PM
xaivior's Avatar
Car: Camaro
Engine: 355
refabrication isnt going to work i need the car for work (daily driver) that would take too long...anyone have any other ideas that can be done fairly quick?
Old Oct 28, 2004 | 03:00 PM
-ZERO-'s Avatar
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
you could always put your old stuff back in the car untill you figure out what to do.
Old Oct 30, 2004 | 03:50 PM
xaivior's Avatar
Car: Camaro
Engine: 355
well im screwed on that one I done a stupid thing ......allready trashed the old stuff
what about something like these and what are the drawbacks of using them??
Old Oct 30, 2004 | 06:55 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
cam you post a picture of this problem? I have the same tq arm and did not have any clearance problems. however my car is not lowered.
Old Nov 5, 2004 | 05:42 PM
xaivior's Avatar
Car: Camaro
Engine: 355
I can try if i can get a camera ......mine isnt lowered either . i have 70r15's on the back with a and 60r14's on the front so it sits kinda low in the front
Old Nov 5, 2004 | 10:44 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
cough...spohn is better...cough, damn this cold
but seriously, the driveshaft loop is the lowest, and its never scraped anything. btw, ive got a pro kit on my car
Old Nov 9, 2004 | 06:05 PM
xaivior's Avatar
Car: Camaro
Engine: 355
well I tried to get a camera but no luck... what about the parts I posted a pick of are they safe?? will they cause any damage to anything??
customblackbird
Aug 15, 2021 10:16 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IROCZ1989
Jan 24, 2016 03:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
