Adapter Problem
Old Oct 28, 2004 | 02:06 PM
slm91z28's Avatar
Car: 1991 Z28
Adapter Problem
hey guys... i wanted to know if anyone has had problems with adapters on their cars... i put 2" adapters on my car all around with a set of y2ks and my car shakes now everytime i hit a dip or a bump... is it the adapters or is something else the problem... if you guys could help me out or give me some information... thanks - stephanie
Old Oct 28, 2004 | 02:19 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Step, I will assume for certain that when you put the new rims on the car that they were a larger diameter rim (ie-17" or 18", not stock 15" or 16") and they were wider also.
The byproduct of doing so is the wider low profile tires will ride much rougher than the factory taller sidewalls intended for these suspension designs. You will in fact feel any road imperfection much harsher with those new rims and tires, combined with the older suspension probably having worn bushings will dramatise the effect even worse.
It is very unlikely that the wheel spacers are causing this.
Dean
Old Oct 28, 2004 | 02:41 PM
-ZERO-'s Avatar
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
you still might want to check that all is tight under there cause you dont want your wheel falling off on you.
Old Oct 28, 2004 | 03:50 PM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
where did you get the wheel adapters from? The only ones I have heard of failing were a pair that someone was using that were homemade. When he was asked specifics about the failure he did not respond. If they are hubcentric you should have no problems.
https://www.thirdgen.org/techbb2/sho...light=adapters
Old Oct 28, 2004 | 05:55 PM
slm91z28's Avatar
Car: 1991 Z28
The adapters are from Motorsport Technologies. These are custom fit hub centric adapters. I had no problems with the car shaking till I mounted the Corvette rims...so I recently switched back to my rally wheels, and problem solved. The adapters don't fit snug on the hub, could it be that I need rings on them, or is the geometry corrupted on my car.
..All suspension has been checked and torqued down to spec.
Thanks...
Old Oct 28, 2004 | 06:00 PM
KiLLJ0Y
Guest
Posts: n/a
shaking when driving normal? or when you hit bumps and stuff?
i had 2" spacers all around on my car with Zr1's, i didnt get shaking. bigger wheels and smaller tires do make your ride quality suck a bit, but thats expected.
Old Oct 28, 2004 | 07:41 PM
slm91z28's Avatar
Car: 1991 Z28
the car shakes at 50+ mph only when you hit a small bump... normal driving does not shake.
Old Oct 29, 2004 | 07:31 AM
Engine: 5.7, 5.0
I run 2" http://www.skulte.com adapters and fourth gen wheels with no problems.
Old Oct 29, 2004 | 06:00 PM
Wolfpack's Avatar
Car: 86 Iroc
Might be Silly....but have the New Rimes and Tires been Balanced Correctly?
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
