Strut Tower Brace
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
Strut Tower Brace
Who makes strut tower braces for camaro's other than TPI?
I have an 84 Z28 L69, and i cant find anything for it.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Strut Tower Brace
Car: 84 Z28
Engine: 305 L69
The Edelbrock TBI STB should fit unless you have air-conditioning. It won't clear the driver side compresser mount bracket. I had to go with the Jamex STB.
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Does anyone know where a upper strut-tower brace for a 92 camaro with a 3.1 V6 could be aquired? The car has A/C, if that makes any difference.
~Max
~Max
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
STRUT tower brace
i have a carb'd 87 ta that i have the h/o dual snorkle air cleaner on . my edelbrock tbi does fit with littleb mod to a/c comp braket and support it looks good its light and what a difference! WOW:lala:
Car: 83 Z28, 84 Z28
what type of modification has to be done? and what is the part number on your strut tower brace?
Car: 90 Formula 350
strut tower brace
the rod that goes from opper brkt to intake is removed and upper corner of upper brkt was trimmed with a sawzall takes abot 10 min and never had to remove it -done in car. comp is still mtd well and no problems
Car: 84 Z28
Engine: 305 L69
Sorry, I wouldn't go along with the above Mod. That support rod is there for a reason, you may not see problems right away, but something will start cracking in the future. If you could mod the bracket to accomodate that support rod I'd say go for it.
Car: 90 Formula 350
strut tower brace
yes its there for a reason but dosent affect it without it its been a year snd 15,000 miles since i did the . have you tried this? i have and it works and i do have the zz4 intake and dual snorkets on my car
Car: 84 Z28
Engine: 305 L69
Jamex doesn't make their STB anymore. I picked mine up thru the classifieds on this site. You may try posting a parts wanted.
I didn't mention this above but the Jamex is only a two point brace.
Car: 83 Z28, 84 Z28
Im sorry but i dont think we gaind anything from this post lol
i cant find the answer to that question anywhere in there.
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Originally posted by 91banditt2
MAC also make a STB for TBI/Carb.do a
for MAC STB
for MAC STB click here
this STB was designed for use with a TBI motor but will also work on a carbed motor.
LT1Formula
Oct 8, 2015 08:34 PM
tcflint
Sep 27, 2015 05:58 PM
