Coil Spring question
Old Nov 7, 2004 | 10:44 PM
Red25thRS's Avatar
Car: 1992 camaro rs
Engine: 305 TBI
hey guys got a 1992 Rs...Ok i dont wanna get eibach springs cuz i dont wanna lower my car and have to get a adj panhard bar right yet..dont got the money for it....im pretty sure i have the stock springs on it....it i got a set of iroc springs would it stiffen my ride up cuz im gettin the floating effect...i remember when i first got my car u couldnt push down on it at all it would barely move but now if u push down on it...its like a water bed...will the IROC sprigns cure that
Old Nov 7, 2004 | 10:48 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
click on spohn (sponsor at the top) and get some moog replacement springs
Old Nov 8, 2004 | 09:22 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Just food for thought. I have the Eibach Pro springs & my rear has not shifted.
Old Nov 9, 2004 | 12:21 AM
Red25thRS's Avatar
Car: 1992 camaro rs
Engine: 305 TBI
so your rear is still fine becuz i do not wanna get the adj panhard bar...im short for money...its just i want stiff springs for handling....when i hit the gas my rear end squats like helll and when i brake my nose dives like crazzy...i know i need new springs...u think ill be fine with the pro kit and not have to get the adj panhard.....cuz i got monroe reflex's on the way and the wonderbar and STB...everything on the front is original so i think i should see a huge diff
Old Nov 9, 2004 | 06:28 AM
oil pan 4's Avatar
Car: 89 Firebird
If your car bounces up and down like a water bed it is most likely bad shocks and struts.
GM shocks and struts don't die over a long time, on me any way. They go fast.
If you chang the shocks and struts it should make the bouncy ride go away, V8 springs will make you ride a little higher too.
Old Nov 9, 2004 | 07:40 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Chances are the IROC springs you have are worn out to. I would just get mooge replacment springs or go with BMR, hotchkiss or the prokit which only give you around a 1" drop. Your rear end does shift but it is more noticable the lower you go. With only a 1" drop you could feasable get away with the stocker. But lowering your car any amount changes its geometry and static posistioning of some parts.
Old Nov 10, 2004 | 08:17 AM
Red25thRS's Avatar
Car: 1992 camaro rs
Engine: 305 TBI
Thx for the help guys....got my reflex shocks today and put them on and it was a huge difference...much better ride...i dont bottom out anymmore lol.....just orderd Iroc springs i dont wanna mess up the geometery of my car soo im stick with iroc springs
Cameeeero
Sep 18, 2015 04:00 PM
TheExaminer
Aug 25, 2015 07:34 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
TA8487
Aug 11, 2015 09:02 PM
