Brake line size?
Old Nov 12, 2004 | 11:52 AM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
Brake line size?
Anyone know the size of the brake line?
my brake line busted on the rear drivers side im not sure if it's the line going from the front to the rear or the smaller one but i was looking on autozone and they want to know the size and length of the line
Any help?
thanks
Old Nov 12, 2004 | 05:47 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
www.finelines.com
great fast shipping if you can wait that long factory reproduction bends and all work real good. parts store will give you straight peice and tell you to bend it to fit.
jeff
Old Nov 15, 2004 | 01:12 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Brake line size?
Any help?
thanks
'The fronts require a 3/16 hard line until you get to the soft line. The rears untill the soft line right before the rear axle is a 1/4 line.
Reddeath210
Oct 6, 2015 08:20 AM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
