eibach drag spring pics/info ????
Old Nov 23, 2004 | 08:52 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
eibach drag spring ride height ?
ive searched and searched. for the people that use these springs, all i can find is "its sits a lil low in the front"
how low?
does anyone have measurements of before and after?
ive done some weight reduction to the car and the stock IROC springs are to stiff for the car now. they worked great before i took 125# out, but its a 4x4 at the moment.
dont know if i should put the drag launch springs in or use v6 springs.
thanks!
Old Nov 24, 2004 | 07:41 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
anyone?
Old Nov 24, 2004 | 09:39 PM
lowbgtRS's Avatar
Car: 94 Camaro
Engine: 383 Stroker
um....i think the drag launch springs have different spring rates between the left and right sides, for hard launches. I dont think they are what youre looking for. So are you looking for softer springs?
lowbgtRS's Avatar
Car: 94 Camaro
Engine: 383 Stroker
you might want to look for some RS springs or something.
Old Nov 24, 2004 | 09:45 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
yes. looking for softer springs to set the front back down.
the rear springs are different, but both front springs are the same part# and spring rate.
Old Nov 25, 2004 | 12:50 PM
onefast85's Avatar
Car: 85 camaro
Engine: 605in bbc
Transmission: powerglide
Axle/Gears: 12bolt with 4.10's
if you are drag racing i would put moroso trick springs on it.thats what i have on mine and they rude on the street just fine.
Old Nov 25, 2004 | 02:38 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
ive been wanting the trick springs, but ive got the eibach drags here, so i might as well try them. you could say they were free. hehe
Old Nov 25, 2004 | 06:57 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
put the eibachs in.
RAISED the car an 1 1/4 over iroc springs
CUT 1/2 coil NOTHING.... same height
CUT 1/2 coil more
2 frikken inches lower now! holy moly, a lil too low, but it looks great.
hopefully someone can use this info and learn from it. i made a mistake in my case.
Old Nov 27, 2004 | 01:12 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Originally posted by stage20
put the eibachs in.
CUT 1/2 coil more
not possible....if you cut half a coil it will drop regardless unless you put them in wrong. less spring=lower anyway you look at it. they might not have settled down to their ride height but they will drop. and i know people who have taken 2 coils off and their cars still sit high, just depends on the weight in the front of the car.
Old Nov 27, 2004 | 03:47 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
anything is possible.
like you said, depends on the weight of the vehicle.
ive got some 4th gen new rear isolators on the way, should be here monday.
92projectcamaro
Dec 8, 2015 12:25 AM
Antips16
Oct 30, 2015 06:42 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
JSDaddy189
Sep 26, 2015 03:50 PM
Dragonsys
Sep 25, 2015 03:51 PM
