Bigger Tires=Worse Handling?
My '83 Z originally came with Goodyear Eagle GT's, 215/65-15. If I go to 235/60-15's in an equivalent Goodyear tire, would the handling be worse with the fatter tires? I'm wondering if bigger tires would flex more when cornering.
Larry
Larry
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
having new tires prolly will hurt your handling a bit.
new tires have lots of tread deapth and that tread likes to squirm which will allow it to slip a little more.
Car: 1992 Camaro RS Convertible
Engine: 3.1
actually your handling will probably remain about the same. The only thing that would make a huge difference in handling is changing the rubber compound you are running on, or changing the height of your sidewall. Since you went from a 215/65 (~140 sidewall) to a 235/60 (141 sidewall) you probably won't notice any difference in handling. In traction you might see a little bit of a difference due to the increased surface area of the tire contacting the ground
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I have 235/60-15's on the rear, it handles much better then it did before with the worn out snow tires i had back there, lol.
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
It's kinda complicated. A wider contact patch will tend to give you more traction, especially in a straight line and dry conditions. But if you put a wider tire on the same width rim then you might notice some more squirm while turning. Typically a wide rim with a narrower tire would give you the best 'feeling,' but not the most traction. It really depends on the sidewall construction and tread compound. Also a shorter side wall will also help.
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
How did u figure iout the sidewall heights like that?
Car: 2005 BMW 545i
Engine: 4.4L N62B44
means 215mm cross section
60 is how tall the tire is. it is based upon the percentage of cross section
so 60 means 60% of 215 which comes to 139.75
http://www.miata.net/garage/tirecalc.html
