How can you tell if its a 9 bolt or 10 bolt
Old Dec 2, 2004 | 07:16 PM
91NiteRida''s Avatar
Car: 1991 Camaro
How can you tell if a camaro rear axle is a 9 bolt or 10 bolt??Is it as easy as counting the bolts on the diff cover?All and any info is greatly appreciated.
Old Dec 2, 2004 | 07:18 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
yep if theres 9 bolts holdin the cover on otsa 9 bolt, 10 botls-10 bolt 12 bolts-12 bolt ect
Old Dec 2, 2004 | 07:25 PM
Car: 1991 Camaro
thanks for the info...time to post a new question now that i know what type of axle i have
Old Dec 2, 2004 | 10:30 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
The 9bolt also has a rubber plug in the cover ...
Old Dec 4, 2004 | 10:25 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
what type of axle? what exactly do you need to know? also the sho fire bonified way to tell if ya have a borg is look in the bottom of the pumpkin. it has the borg warner insignia there.
Old Dec 6, 2004 | 04:04 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
What is the advantage of having a BW 9-Bolt over the normal 10-bolt? IS the BW unit stronger? Does it still have the dreaded c-clips?
Old Dec 6, 2004 | 04:20 PM
1320 Right Ln.'s Avatar
yes it is stronger, no c-clips, and 4 spider gears in the diff vs. the 2 in a 10 bolt. I had one in my 89 IROC... but they're hard to find in the popular axle ratios. mine was a 2.77... getting lower ratio's is either very expensive, or hard to find.... or both i guess. Overall... now that I have a 10 bolt, I have to say that the 10 bolt is much easier to live with. parts are WAY more accessible, ring/pinions can be had right out of the summit catalog, blah blah blah... n' I still haven't had a failure with slicks on. No, I don't have a trans brake...
Old Dec 6, 2004 | 07:28 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
1320 pretty much coverd it. a borg rear is/was rumored to be as strong as or stronger than a dana 44.
there is one place i know of to get parts for these rears. miles at diff soultions.
WWW.DIFFSOULTIONS.COM or WWW.9BOLT.COM
2 addys same site.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
