87 10 bolt disc brake axle vs 91 drum brake axle shaft
Old Dec 6, 2004 | 11:21 PM
91NiteRida''s Avatar
Car: 1991 Camaro
does anyone know if the axle shafts are interchangable between a 87 10 bolt disc brake axle compared 91 drum brake axle shaft?
Also what are the years that use the same parts for a rear axle?82-87 and 88-92?
All and any info will be greatly appreciated.
Old Dec 8, 2004 | 12:35 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Re: 87 10 bolt disc brake axle vs 91 drum brake axle shaft
Nope. In mid 89, the rears changed from 26 spline to 28 spline.
Old Dec 8, 2004 | 07:46 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
Not only are the splines different, but the axle flange on the drum brake is slightly larger than the disc brake axle. Not a big deal unless your planning on using the older style rear disc setup, in which case the rotor won't fit over the axle.
I found this out the hard way last week
Eric
1992rs/ss
Jan 31, 2025 05:10 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
red90IROCls1
Aug 25, 2015 06:56 AM
Jlanz55
Aug 17, 2015 07:15 AM
