S&WRacecars' Roll Cages?
Anyone used or have any real world experience with S and W Race Cars' 10 pt roll cages and sub-frame connectors? Is it their own design cage, or are they just a re-boxed CE cage? How are the bends and how comprehensive is the kit?
Thanks in advance for the input and comments
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Ohhh let me be the first........
First click the button near the top on the right that says , then type [s&w]
Engine: 4++,350 & 305 CIs
Heres mine
http://www.team3rdgen.com/modules.ph...bum.php&page=3
Its a S&W kit .. had to tweek some of the bars a bit but nothing bad ...just take your time and measure everything 5 times if you have to...good luck
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Tony,
I definately enjoyed seeing your car at thirdgenfest. are you planning on bringing it out again this coming year in 05 ?
I should have mine back from paint by then and it'll be all one color for once.
I'm going to try.. I just bought a house and i think it'll take more of my time and money than I want it to but oh well...I need to work my heads over a bit ,get a trans put in ,finish my aluminum hood and pull out my aluminum 9" to give it the once over
Car: 1 68 bird, 2 87 birds, a 92 bird...
Engine: carb'ed 305 in the 87, yuck...
Transmission: 700R4, for now....
Re: S&WRacecars' Roll Cages?
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Only thing I didn't like about the kit was the swing outs. If you get them, there in a 2 piece weld together form for each side. So you got to put a bolt in them before you weld. Else the top bolt hole and the bottom hole can get distorted. Mine got a little tweaked after that but nothing a die grinder couldn't fix. I think Comp Engineering has a 1 piece prefab weld on.
If I did it over again I would still use the S&W kit, but just order the comp engineering swing outs out of summit or jegs.
Originally posted by KagA152
holy ****, you did a number on that trans tony
1 Post
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I just posted this in another thread, but here's my S&W 8-point roll bar installation notes for you:
https://www.thirdgen.org/techbb2/sho...hreadid=271845
Hope this helps,
--Dan
Hope this helps,
--Dan
Car: 1988 Camaro
I like S&W's work. I bought thier sportsman (14 point) cage for my 78 trans am. Pretty good over all fit.
All of S&W's stuff is 'made in house' no reboxed brand X. They go all the bending, cutting, welding, etc on thier stuff.
Shipping was pretty fasy, and fair price wise. Fed Ex shipping
[MN] S&W 8 point rollcage
FueledSoul
09-30-2015 09:18 PM
tmork454
09-29-2015 06:33 PM
